  • 1994 - 1995 Specific Tech
Short Belt quick question
  • Thread starter Thread starter SuperDust22
  • Start date Start date Jul 10, 2004
First Prev 2 of 2
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 11, 2004
#21
  • Jul 11, 2004
  • #21
Did you use the green or 100% blue routing with the 81in. belt? I want to run a short belt to bypass my smog pump, but I don't want to run the waterpump backwards like the blue line does.
Scott
cb18201
1,140
CT
Jul 11, 2004
#22
  • Jul 11, 2004
  • #22
you cant run the water pump backwards, all the pulleys go the same way, they are just stating which way the water pump spins on that diagram, it can only go one way which is counter clockwise. also did anyone else do this notice there car getting idle surge more?
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Jul 11, 2004
#23
  • Jul 11, 2004
  • #23
I ran it 100% the blue way and it does surge a little at idle and I have stalled a couple times.
Dustin
cb18201
1,140
CT
Jul 11, 2004
#24
  • Jul 11, 2004
  • #24
yea same here, anyone know what caues this or how to stop it?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 11, 2004
#25
  • Jul 11, 2004
  • #25
You are right. I was about to throw up a bunch of to you!
Thanks for the clarification!
Did you guys block off the smog tube at the h-pipe? Maybe exhaust is coming through the smog tube and doing something wierd?
That's the only thing I could think of.
Scott
cb18201
1,140
CT
Jul 11, 2004
#26
  • Jul 11, 2004
  • #26
i didnt take any of my smog off, i just by passed it.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Jul 11, 2004
#27
  • Jul 11, 2004
  • #27
All of my smog stuff is gone. O/R H-Pipe is blocked. Make sure your vacuum is blocked as well !! If you remove everything of course. I think it's pink. Just stick a small nail in there with some silicone. That could cause your surge for sure.
SuperDust22
Oct 19, 2003
1,821
Gilbert,AZ
Jul 11, 2004
#28
  • Jul 11, 2004
  • #28
Same here. But I am not going to run this belt everyday. I live in AZ. It's like a 110 here. I might use it in the winter. And I might buy another belt that bypasses the powersteering for the track.
Dustin
SuperDust22
Oct 19, 2003
1,821
Gilbert,AZ
Jul 11, 2004
#29
  • Jul 11, 2004
  • #29
Stangfreak95 said:
All of my smog stuff is gone. O/R H-Pipe is blocked. Make sure your vacuum is blocked as well !! I think it's pink. Just stick a small nail in there with some silicone. That could cause your surge for sure.
Thanks Stangfreak95. I will try that today. You have been a lot of help on this. Thanks. And were is the pink vacuum line anyways?
Dustin
Stangfreak95
add a 4
3,571
Jul 11, 2004
#30
  • Jul 11, 2004
  • #30
Dustin
Sorry I assumed you were taking everything off. If you do remove the whole air pump stuff, you'll have to block that pink vacuum. But I think you're keeping yours so dont worry about the vacuum, I'd say.
It's a 3way vacuum. Attached to it, there's a RED, GREEN and PINK. The red goes through the elbow near the fuel pressure regulator, the green is for the EGR and the pink for the smog pump.
SuperDust22
Oct 19, 2003
1,821
Gilbert,AZ
Jul 11, 2004
#31
  • Jul 11, 2004
  • #31
No I am keeping everything so I don't have to worry about it. If I ever got a another car and this became my weekend car I would take it all out.
Dustin
haulbalz
448
#32
  • Dec 30, 2005
  • #32
TTT
First Prev 2 of 2
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
