Have them install screw in freeze plugs. You do not want to lose a motor due to one of them popping out.
I disagree.
The "freeze plugs" are designed to keep your block from splitting due to lack of anti-freeze in cold weather.
They won't "pop out" unless the owner doesn't keep proper levels of anti-freeze in their cooling system in extended sub-freezing winter weather.
Usually the car would have to be parked outside as well, and unless the temp gets down near zero, the car would have to be left outside AND undriven for days to release the freeze plugs.
You really have to neglect a car to have the freeze plugs release is the point.
I have had them pop out of a 302 left outside in abnormally cold weather for a week.
Kept my block from cracking. (Memphis TN)
Here in Pensacola we had a very cold night, temps near 20*, and my son had pure water in his car, the radiator froze solid... And his freeze plugs held. Scared the crap out of him. The water pump wouldn't even spin.
Don't be scared of freeze plugs, they are your friend. If you want the best, use brass plugs, they don't rot out like the steel ones can after a few decades.
