Short Throw Grinding!
  • Thread starter Thread starter gofast_beloud
  • Start date Start date Apr 5, 2005
G
gofast_beloud
35
  • Apr 5, 2005
Hey guys. Im not sure of the manufacturer of my short throw, but when i gear down to second and i let the clutch out it grinds sometimes and throws it out. Also going into reverse it grinds or the clutch needs to be half way out to get into reverse..If anyone knows wat the problem could be cause its pissing me off and ruining my tranny slowly!! thanks guys!
90_Red_LX
668
Asheboro, NC
Apr 5, 2005
  • Apr 5, 2005
Pull the shift boot and check your stops. I bet it's loose and is hitting. Set them right and tighten them up real nice.
notchback
1,950
St Clair Shores MI
Apr 5, 2005
  • Apr 5, 2005
it's not the shifter ... it's the tranny
squeeeg
1,905
Michigan
Apr 5, 2005
  • Apr 5, 2005
I'm betting on it being the old t5 going out.
Q
Quijibow_69
44
Mechanicsburg, PA
Apr 5, 2005
  • Apr 5, 2005
I just had the same problem. I installed the Pro 5.0, checked the stops and it still did it. Recently though, it hasn't been doing it. I think my hand-foot coordination was wrong. I'm finally getting used to it.
NKau
1,346
Jefferson, WI
Apr 5, 2005
  • Apr 5, 2005
Ha, seems like a lot of people have this problem; I know I did.
As far as reverse; it should grind, it's not a synchronized gear. Shift into 5th, and then down into reverse; that should keep reverse from grinding, and save some wear on it.
Speeds8erM-1
1,240
Pensacola Florida
Apr 5, 2005
  • Apr 5, 2005
It's your transmission and what NKau said is right, shift to another gear before going to reverse, it's not synchronized.
kornchild4life
46
islip, ny
Apr 17, 2005
  • Apr 17, 2005
my tranny has been having that same problem with going into reverse and i have the stock shifter also noticed just today that it seem to have been stiffed shifting why??? its been fine for since i've had it and i've been shifting fine since i've own it
bmorrisj
449
Buena Park, CA
Apr 17, 2005
  • Apr 17, 2005
your syncros/dog rings are going out...
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
