Short throw shifters worth the cash?
1987stangman
684
24
Hi everyone, I have decided to buy a short throw shifter for my 87' GT next week and as I have never driven a Mustang with one wondered if they are worth the cash. Also, I have been looking at the Pro 5.0 but the MAC is a little less expensive. Does anyone have any good or bad things to sat about the MAC?
Brian
one of the best investments ever is s hort throw shifter. It changes the entire feel of the car.
I've ran a pro 5.0 for years, and my bro the steed tri ax. for years, those two dominated, and I wouldn't run ANY other than those two, but now MGW has entered the scene, and seems to be a kick ass shifter. Stick with any of those and you'll be ok.
MGW hands down. :hail2:
http://forums.stangnet.com/showthread.php?t=528042
Search will turn up a ton of stuff on MGW.
Here is George's website.
http://www.mgwltd.com/mustang_shifter.shtml
Definately worth it.
The stock shifter is total garbage.
I have a Steeda Tri-Ax.No complaints other than the aluminum handle which I replaced with a billet steel handle.
I'm surprised no one else has mentioned that they also help with preventing transmission breakage. I've never seen an aftermarket shifter that didn't have adjustable stops, so you're not bending or breaking shift forks in the trans. With the factory shifter, you can "overthrow" the shift, but the aftermarket prevents that.
Thanks everyone, I think that I am gonna go with the Pro 5.0, because your right the stock shifter does suck. I will post up when I get it and get it in. I hate waiting and Racer Walsh is near my job so I will see if they have it right in stock.
Like stated above it does help prevent transmission breakages when you shift hard. Bending or breaking a shift fork will happen within a few powershifts. As far as helping you run a quicker time, no not really, but once you adjust to it you will think it's money well spent. Nothings more frustrating then missing a gear. And missing gears can be rough on your drivetrain, especially when valves float with no load on the motor. I use a pro 5.0 and driven a steeda tri ax. I liked both, but the steeda comes with a longer handle so it's a little easier to drive imo. What pissed me off though was MGW came out with their shifter just a couple months after I got mine, and thats what I really wanted. Oh well. Just stick with Pro 5.0/Steeda tri-ax/MGW (ftw imo) and you'll be good. Just be sure you set your stops properly and tighten the s*it out of em. Myn would work their way loose when I didn't tighten them that much and it would pop out of gear. Losing 1st, 3rd, and 5th while driving isn't fun at all.
