Well, I've been thinking about buying another car since the Mach still isn't done (it's still sitting in Tampa, I'm in Seattle). Pops says he'll get it on a transporter by mid November, but he's been saying stuff like that for near 2 years now.
To the point, I've found an '89 AOD 5.0 Mustang coupe for $1000 here in Seattle. I haven't looked at it yet, but the owner says it runs good, drives well, doesn't burn oil, and is generally in decent shape for having 164K miles on it. The only issue he indicated in his email is that it does have a cooling problem. He says it gets hot enough to push fluid into the overflow and leaps the divider barrier into the washer fluid container (since they're a single unit).
Now I don't have a ton of experience with 5.0s specifically, but regular overheating on a high mileage motor concerns me as it typically means a bad head gasket or the like. Sure, I know it could be a bad water pump, bad radiator, bad cap, etc, but can anyone with more experience offer any 5.0 specific sources or reasons for overheating? Other than water in the oil, or oil in the water, or leaks, what else should I look for?
Thanks in advance all.
Prob head gasket time,
me personally if it is indeed a coupe and not a hatch i'd be all over it, the coupe makes amuch better race car, either drag or corner carver than the hatch since the unibody is much stronger
), but I'm not sure what $1000 will really get me at this point. It might just cover an EFI conversion if I've got to source everything separately, or it might get me an AOD rebuild, or maybe most of a set of heads, but I'm not sure that is really worth much on a stock '70 302. Makes that 5.0 sound better and better.
