should i buy the e cam?
  • Thread starter Thread starter gmohanva
  • Start date Start date Jan 22, 2006
1 of 2 Next Last
gmohanva
Portsmouth,VA
Jan 22, 2006
  • Jan 22, 2006
ok i have a friend that will sell me a brand new, never used e cam for $50. he is getting bigger cam for his motor. i was thinking that will be a good idea for that price, considering that cam costs about $150 to $200. right now i just have 3.73s and rebuilt aod with shift kit and tranny cooler. i will plan on doing the h/c/i combo later on. my question is, is it worth putting this cam in just like it is in this stock motor with 150,000 miles or finish saving up for my exhaust system that is coming for the spring? and what's the pros and cons for putting this cam in a stock motor. ps it is a daily driver.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 22, 2006
  • Jan 22, 2006
i don't think you can ever go wrong with putting a cam in. for 50 bucks and the cost of a few more gaskets i say do it. as long as you don't have to remove your heads. if you have to do that then the gasket cost starts to get expensive.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jan 22, 2006
  • Jan 22, 2006
Thats alot of work for maybe 10HP..I would wait for the heads and intake so you can appreciate the characteristics of the cam more. HP the cam CAN generate will be bottlenecked by the flow abilities of the stock heads and intake...you may infact find the low end torque significantly decreased.
Paul Perreca
1,085
  • Jan 22, 2006
agree with dman, you have to pull more than half the motor apart to do the cam anyway, instead of just pulling it apart installing the cam, and putting it back together, might as well put it back together w/ aftermarket heads n intake while your already torn apart -
mustangramair
326
Iowa
Jan 22, 2006
  • Jan 22, 2006
I would wait and buy a cam that is suited for the heads you will be purchasing. If you don't know what heads you are getting i would wait. Plus i wouldn't cam stock heads with no work done to them.
1EVIL88VERT
314
Dyess AFB, TX
Jan 22, 2006
  • Jan 22, 2006
Buy the cam and sell it on e-bay.... i promise you will get more than 50 for it.
Sicarius428
2,085
Jan 24, 2006
  • Jan 24, 2006
You are probably best off sticking with the stock cam for the stock motor. You can potentially hurt your low end with just a stock block.
Kevin
MAC'n89Blckstng
1,012
NJ
Jan 24, 2006
  • Jan 24, 2006
I have the e303 cam in my car, and she pulls hard from 3500 5500 , lost alot of low end torque tho
fiveohwblow
Official Member
2,169
145
155
Jan 25, 2006
  • Jan 25, 2006
Not to thread jack... but is that what the e cam is best for? Modified? I ask because I just bought a set of Twisted Wedge heads and dont know the proper cam. I want a custom cam, but will it benefit me enough to weigh the costs?
I figure this will help GMOHANVA in the long run with info, but sorry if you feel I am threadjacking...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 25, 2006
#10
  • Jan 25, 2006
  • #10
Many will tell you the E cam is best for propping open doors that want to blow shut....
The E is identical to Crane's old 2040 cam (Crane designed the E for FRPP); here's what they recommend to go along with that cam.....
"GOOD MID-RANGE AND STRONG TOP-END POWER, REQUIRES MODIFIED MASS AIRFLOW, AFTERMARKET INTAKE, PERF. CYLINDER HEADS AND HEADERS, MUST USE 5-SPD AND 3.55 OR NUMERICALLY HIGHER REAR GEARS. REQUIRES CRANE SPRINGS AND RETAINERS. (50 STATE LEGAL 85-93, C.A.R.B. E.O. D-225-46) BASIC RPM 2400-6000"
Even with the proper mods, the bottom end is usually pretty soft with that cam -- ESPECIALLY for a mostly stock daily driver with an AOD...that's why Crane says 'MUST USE 5-SPD...'
So, if you decide to go forward with it, do the other mods first -- ESPECIALLY the higher speed stall converter.
Sicarius428
2,085
Jan 25, 2006
#11
  • Jan 25, 2006
  • #11
Its great for a performance option that is CARB legal. Fiveohwblow, it is impossible to beat a custom cam but I was really pleased with my TFS stage 1 cam with TW heads. Definately more power than the E. And the price is very reasonable.
Kevin
fiveohwblow
Official Member
2,169
145
155
Jan 25, 2006
#12
  • Jan 25, 2006
  • #12
Kevin
Thanks Kevin, I appreciate the input.
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Jan 25, 2006
#13
  • Jan 25, 2006
  • #13
I wouldn't want to lose the low-end by putting an E in the stock build.
Unless the choppy idle means that much to you.
If you want to have a more aggressive idle than stock and actually make about 20-30 more low and mid range power digits I suggest the Crane 2020.
For $50 unused I would buy it just to make a buck.
I imagine someone surfing the forums would give you $75-120 for it.
TrunkFunk
Banned
Dec 28, 2005
83
Jan 25, 2006
#14
  • Jan 25, 2006
  • #14
The Trick stg 1 cam is good for a 3" stroke Windsor and does match the as cast TW heads well. The TW heads are a little intake biased so the extra duration and lift on the exhaust side with the cam makes them compliment eachother well.
CobraWannabe
321
Lancaster, PA
Jan 25, 2006
#15
  • Jan 25, 2006
  • #15
Michael Yount said:
"GOOD MID-RANGE AND STRONG TOP-END POWER, REQUIRES MODIFIED MASS AIRFLOW, AFTERMARKET INTAKE, PERF. CYLINDER HEADS AND HEADERS, MUST USE 5-SPD AND 3.55 OR NUMERICALLY HIGHER REAR GEARS. REQUIRES CRANE SPRINGS AND RETAINERS. (50 STATE LEGAL 85-93, C.A.R.B. E.O. D-225-46) BASIC RPM 2400-6000".
So, this would be a nice cam with my Cobra motor and C&L 73mm, right?
green95gt
52
cartersville ga
Jan 25, 2006
#16
  • Jan 25, 2006
  • #16
I would buy that cam for $50 quick. But wait till you do your heads and intake to put it in. Your 150k mile stock springs probally won't work with that cam. They will need replacing when you do the cam.
pistonhead351
flim hunter
May 1, 2005
75
#17
  • Jan 25, 2006
  • #17
we put an e-cam in my brothers auto 90 gt, it did not lose any low end torque at all. its actually faster off the line then with the stock cam. has no problem smokin the tires from a stop. hes raced 2 5 speed gt's both with gears and mods and smoked them both. i would just buy it and put it in for the future.
NotQuik
5,158
29
88
Central Florida
Jan 25, 2006
#18
  • Jan 25, 2006
  • #18
I'd personally buy it and sit on it until you atleast get an intake even though that wont maximize the combo it'll still be better than stock...my old coupe trapped 99 mph with just full exhaust, with b-cam and edelbrock performer it trapped 105 and some change, stock maf, t/b, and injectors incase you were wondering. I have an e-cam in my room but cant afford supporting parts for now or anytime soon so i'm atleast going to wait til i get a manifold.
TrunkFunk
Banned
Dec 28, 2005
83
Jan 25, 2006
#19
  • Jan 25, 2006
  • #19
An E cam will lose low-end over the stock cam, period.
Unless your brother's car had some serious timing/ignition related issues prior to the swap.
pistonhead351
flim hunter
May 1, 2005
75
#20
  • Jan 25, 2006
  • #20
i beg to differ but im not gonna argue on the internet. we got the timing set at 18* advanced with no ignition problems or detonation
1 of 2 Next Last
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
