should i buy this cam??
ninety1gt
162
san antonio
my friend is selling this cam for $100 its brand new and list for $189, should i buy it??
Brand: Lunati
Product Line: Lunati Voodoo Cam and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-5,500 RPM
Intake Duration 050 inch Lift: 213
Exhaust Duration 050 inch Lift: 219
Duration at 050 inch Lift: 213 int./219 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Advertised Duration: 256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.483
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.499
Valve Lift with Factory Rocker Arm Ratio: 0.483 int./0.499 exh. lift
Lobe Separation (degrees): 112
Computer Controlled: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: No
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity: Sold as a kit.
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 256/262, Lift .483/.499, Ford, Small Block, Kit
if it were me, i wouldnt do it. i just dont like the idea of something metal and flat sliding on something else that is metal. a hydraulic roller cam just seems like a much better idea than a flat tappet cam. you can get a much better cam like the tfs stage 1 for cheap or a fomoco alphabet cam. just my opinion though
It seems like a nice dual pattern cam that favors exhaust. It is not as aggressive as a stage 1, BUT....it is flat tappet. That is going backwards in tech since you have a roller block. Although its cheap ($100 bucks), a stage 1 is like $50 more. Just re-use your current lifters.
You'll need new lifters, pushrods and valve springs along with the cam -- there went your cost savings and then some.
Leave the stock cam alone -- it's capable of supporting a lot more power once you get the stock head out of the way. Save your $100 and put it towards a new set of heads.
