Should I go 3.55 or 3.73 wit hmy 414c.i.?
It really depends on what your goals or plans are.
If you are not looking into some suspension work, go with the higher ratio.
If you are looking to do some suspension/traction work, go with a steeper gear.
Are you wanting to match this to your trap speed or just for your own personal preference?
Just do whatever you feel comfortable with it:)
My suspension is being beefed big time. I am looking for the ideal 1st gear launch and to be able to shift into 5th at 60 and not ..glug...glug...glug... buck , buck , buck... like it does now. You can hear the drive train clunking a little when it does that,..yo uknow.
Keith
As I see it .....The fifth gear thing you speak about ..........
is gonna be dependent upon the tune more so than the gear ratio
I had a bit of that and I found pulling a small amount of spark from low load conditions really helped with that
Grady
Ok. I am going 3.55. I was just out on the road after installing my edelbrock victor intake. I can't get no..... tra..-tra...-tractIOn.. in 1st, 2nd .
Given it is cold out.... and I am riding on BF Goodrich v 245's rated with - not much traction... the 3.55's will be a much better power band but more traction in warm and with my z rated 255's going on..
p.s. DD, you do have 3.35 1st gear too..I have 2.95. :)
so you like the new intake i take it? :cheers:
um, with higher gears, your traction "problem" is going to be worse.
i'm sure you already know that though.
that is the kind of problem most of us would love to have, huh?
you should try on my rear wheels and tires ... i bet you'd like them
they are these (toyo r888 18x275):
Yes but It is freezing cold out lol. And me tires aint so good. Intake goes around 1k rpm higher..but I need to try it more to get a good feel...DEFINITELY opens up for more power. That 414 needs ALOT of air! Are they drag radials?
... found em'
"Stock Level: Click for details
Summer tires
UTQG: 100AAA
Speedindex W: the tire's speed capacity is up to 168 mph/270 km/h !
Facinating.. basically drag tires with a speed rating and a wear rating that is 1/2 decent...BUT $200 per tire!! lol. Also, how's the side wall?
... found em'
Summer tires
UTQG: 100AAA
geez, i wish mine were $200 per tire ... they more more like $300 per tire. were you looking at 17s? mine are 18s
