OK, I'm torn.
I have the engine apart right now. Just put in a new camshaft, timing chain, afr 165 heads, lunati lifters, etc. All in all I think I've dumped $4K into this revamp.
And I didn't buy an ARP camshaft bolt. I simply reused the stock one, and stuck it back on with loc-tite red. I didn't buy one from flowtech, because he wanted $15 shipping for a $8 bolt, and I forgot to include it in my original order. Now I see LMR has one w/ free shipping, and am second guessing my decision. Not because of the cost of the bolt, but what sort of damage I might cause to the cam trying to back out a heavy duty bolt and replacing it with the ARP bolt.
The second reason I'm thinking of doing it is I keep staring at the dots between the crankshaft which is at 12:00 and the timing belt which is supposed to be at 6:00, but looks a tiny bit off. Like maybe 1/8". I had the dowel facing straight down, but it doesn't look right.
So how likely is it that I might damage the threaded cam trying to pop out the bolt now that's been seated for a few days? Am I overworrying both things, and should just leave it alone? Is it worth pulling it out?
I should be clear that I don't think the stock bolt will fail, but I'm not certain if I can get the timing better aligned.
