Should I invest the money or naw?
916loronzo
Sacramento
Sup guys. I got this 98 gt with 189k non op odometer. The throwout bearing is out and it needs a clutch. With labor and parts it'll cost about 600 to fix. My question is should I just sell the car? I spent about 1800 buying and fixing lil things so far. The car is fun and engine sounds and runs good for the most part.It got a really small engine leak. I just dont know how much longer this car will hold up considering the miles it got. I would like to know what yall think. Thanks
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,061
9,207
224
Massachusetts
Depends. Are you having to contract out and pay someone to fix everything that breaks on the car? Or are you DIYing most repairs?
If you have to pay each time it breaks, i'd sell it. One or two major repairs and you've spend what you probably could have picked up a cleaner, low mileage car for. Those 96-98GT's are bottomed out for pricing right now, so you can get a deal on one if you look around.
If its a project car, then by all means keep it.
916loronzo
Sacramento
I dont have the experience nor the tools necessary for replacing the tranny clutch. If its internal engine parts that break I dont feel I would want to fix it myself. However I'm replacing the rear end clutch pack and replacing rear drivers side wheel hearing. True true. How long can I drive with a bad throwout bearing out of curiosity? Also just wanna say I appreciate your reply
916loronzo
Sacramento
Not sure I really have real advice since if given a chance I tend to keep my cars for extended periods of time. I just crossed over 245k in my 2000 GT.
Awesome! Makes me feel a bit better about my car. What major repairs have you done with your gt? Also do you recommend lucus synthetic oil additive due to the high miles and also what oil weight do you use or recommend for me? Thank you
wmburns
SN Certified Technician
Aug 14, 2009
5,811
499
164
Houston Texas
How about a whole salvage yard motor and rebuilt drive line?
I brought the car with a locked up motor. The timing chain guides had broken and the pieces of plastic fell into the oil pan. This blocked the oil pick up thus starving the top end of oil. Needless to say the original motor was toast.
The original motor was a casualty of the original owner's poor maintenance and ignoring problem signs. So again I'm not the best case to compare because technically it has taken two motors for me to get to 250k miles. But...... I do hope to make an additional 100K on top of the current 245k. My intent is to completely use up the car and walk away from it.
Reactions: 916loronzo
Thread starter Similar threads Forum Replies Date
A Should I bother (re)investing into my 96 Mustang GT or should I sell it? 1996 - 2004 SN95 Mustang -General/Talk- 4
BlueOvalStangGT What clutch should I invest in?? H/C/I Supercharged car......PART TWO! 1994 - 1995 Specific Tech 4
BlueOvalStangGT What clutch should I invest in?? H/C/I Supercharged car...........(KILLERCANARY LOOK) 1994 - 1995 Specific Tech 34
R what chip should i invest in SN95 4.6L Mustang Tech 2
19notch93 should i invest in some new parts? Fox 5.0 Mustang Tech 4
D How far apart should LT header exit pipes be - x pipe won’t fit headers SN95 4.6L Mustang Tech 1
H 2000 mustang gt should I supercharge 1996 - 2004 SN95 Mustang -General/Talk- 4
markinms Engine Should Auto Trans Be in Drive When Setting Base Idle Fox 5.0 Mustang Tech 7
LILCBRA This should be required viewing for haters 1974 - 1978 Mustang II Talk & Tech 9
C 1998 v6 automatic should I manual swap it? 1996 - 2004 SN95 Mustang -General/Talk- 4
revcor Suspension Previous owner installed cheap no name coilovers, included a box of a bunch of extra coilover hardware, should I be concerned? Fox 5.0 Mustang Tech 1
L Just bought 2010 GT with 38k, what should I look out for? 2010 - 2014 Specific Tech 3
S Should I mod the 302 or run the 390? 1965 - 1973 Classic Mustangs -General/Talk- 34
1989FoxFan Interior and Upholstery [Solved!] Should I replace the pads and cables for my top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
A How should I go about getting to 600hp? 2005 - 2009 Specific Tech 3
Prerunner5.0 Buying a 5.8 swapped Stang, anything I should be aware of? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
79pace Moates / TwEECer / MicroSquirt? Which one should I look into? Digital Self-tuning Forum 16
K Fox Should I/would you still use single after market gauges? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
9 Should i buy a 3v 2005 - 2014 S-197 Mustang -General/Talk- 2
derek2079 After installing a 195F Thermostat my car runs hotter and I don't like it. What temp should I run? I don't know what temp was in there before? Classic Mustang Specific Tech 9
D 19641/2 Mustang convertible valve covers need to know what color they should be 1965 - 1973 Classic Mustangs -General/Talk- 15
Mstng93SSP Should I just swap the whole tank? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 31
M Digital Tuning What should I set my AFR to? Fox 5.0 Mustang Tech 10
J What should I put in a 1998 GT roller? SN95 4.6L Mustang Tech 1
K (UPDATE, more pictures!) I was just offered a Fox Body for $1,000. Help me decide if I should take on this burden 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 44
E Rebuilding need advice as to what kit I should get and what bore 1994 - 1995 Specific Tech 19
Hudson N Should it run with IAC unplugged? 04 gt SN95 4.6L Mustang Tech 6
J What setup should I choose, ,331,or 347? Fox Engine Swaparoo 4
M manual calls for 6qts what should dipstick read 1996 - 2004 SN95 Mustang -General/Talk- 1
gonzo.ayres looking at selling my mustang ii and buying an s197. Anything i should look for and look out for? 2005 - 2009 Specific Tech 6
79 Fox Fox What seats should I get? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
C Should I get this Mustang? 1996 - 2004 SN95 Mustang -General/Talk- 5
N New guy, bout to get teenage dream: Triple Black GT (prem) 'vert ('05). What should I get first? 2005 - 2014 S-197 Mustang -General/Talk- 5
C Suspension How much should I lower an 86 with 96-2004 SN95 spindles and P245/60R/17 tires? Fox 5.0 Mustang Tech 2
C What's it Worth? should i buy this fox body and what should i ask What is it Worth?!?!? 6
T Should I change the fluid in my 1990 AOD? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
FastDriver What parts should we start hoarding? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
P Should I? 1996 - 2004 SN95 Mustang -General/Talk- 6
M Should I get a handheld tuner for my 99-04 Mustang? 1996 - 2004 SN95 Mustang -General/Talk- 1
H Paint and Body What Should I Do About My Bumper 2005 - 2014 S-197 Mustang -General/Talk- 1
C small block 427, what heads should I run Classic Mustang Specific Tech 16
D SN95 What should be connected next to the grey connector on top of the Ignition Coil? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
James V Fox Should there be a vacuum hose here? MAP sensor. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
E 45,000 mile service? What should I get done, etc. 2015+ (S550) Mustang -General/Talk 11
P Should 2005 year be avoided? 2005 - 2014 S-197 Mustang -General/Talk- 3
P low mile,all original 7up, should I upgrade it or not? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 61
B Should I upgrade to 30lb Injectors? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 31
Onesick99GT What price should I list this for? (Rims+Tires) 1996 - 2004 SN95 Mustang -General/Talk- 1
B Should I Buy this mustang gt 2005 - 2014 S-197 Mustang -General/Talk- 1
S Should I get larger and/or wider wheels and tires for track and time trials 2005 - 2014 S-197 Mustang -General/Talk- 0
