side to side while braking
  • Thread starter Thread starter octaneforce
  • Start date Start date Apr 5, 2011
O
octaneforce
9
  • Apr 5, 2011
i have an 87 mustang gt. when i hit the brakes and let go of the steering wheel, the wheel turns about 2-3 inches side to side. its a very uniform wiggle. i just did the front pads and rotors. its always did this. i knew the pads and rotors wouldnt fix it, but it needed brakes. i am thinking brake hoses? the ball joints seemed okay when i was doing the brakes. i didnt check any tie rod ends or anything tho. the car has 61k miles on it.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Apr 5, 2011
  • Apr 5, 2011
Random thoughts about your description:
Have the alignment checked. You could be toe in/out, have a problem with the steering rack not staying stationary (I'd think you'd notice this just going down the road w/out braking tho), or like you said, a tie-rod end that's not up to snuff. The other thing that comes to mind are perhaps, worn A-arm bushings.
When you coast down a level road, does it veer one way or the other?
When you replaced your pads and rotors, did you look over the calipers really good? What kind of condition are they in? Have they ever been rebuilt/replaced?
You might also pop the top off of your master cylinder... Start the engine, let it idle and brake hard (from a stop). After the application of the brakes, just sit there with the pedal down and have someone else look into the MC and see of you're getting any fluid return (would indicate fluid getting back past the plunger).
Flavadave4
1,044
21
49
Utica, NY
Apr 5, 2011
  • Apr 5, 2011
What do your tires look like?
O
octaneforce
9
  • Apr 5, 2011
it doesnt seem to veer while im driving it down a road. however, i did notice that the a arm bushings are very very dried up. the calipers looked pretty good. i dont remember the last time they were replaced tho. ill also do the mc check that you mentioned. where could i get a set of poly a arm bushings? i think im gonna start there since they should be replaced regardless.
O
octaneforce
9
  • Apr 5, 2011
the tires have about 3k miles on them (this car doesnt get driven much). i dont notice any uneven wear. this car has 20inch rims and the tires are 255's. i dont know the brand of the rim. il have to take a look later.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Apr 5, 2011
  • Apr 5, 2011
Wait, what???? 20 inch rims on a Fox?
Uhhh... do you have a regular set of rims you can put on for troubleshooting at least? Do these monsters stick outside of the wheel wells? How much? What's the backspace and offset?
Oh, and the bushings.... I'd stick with OEM rubber replacements.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Apr 5, 2011
  • Apr 5, 2011
My guess is that it's steering related if a brake job did not cure the issue. Either that, or the brakes have "warped" again due to trying to stop massive 20" wheels. Keep in mind, this car was designed originally for 14" and 15" wheels and Ford had to make changes to get 16" and 17" on there.
Shouldnt cause the issue, but it could be a contributor
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 5, 2011
  • Apr 5, 2011
Your mom drives an 87 Mustang with 20" 4-lug wheels and "Saleen brakes" from the factory? This whole thing sounds like a put on.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Apr 5, 2011
  • Apr 5, 2011
Where did you see, "mom" or, "saleen brakes"?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 5, 2011
#10
  • Apr 5, 2011
  • #10
Look at his other posts.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Apr 5, 2011
#11
  • Apr 5, 2011
  • #11
Hmmmmmmmm.... so the plot thickens. lol
O
octaneforce
9
#12
  • Apr 5, 2011
  • #12
lol sorry it sounds crazy. but work with me, im trying to get information about a car from a woman. not always the easiest thing to do. she said they are 20's. il double check next time i look at it.
87_LX_5.0
142
23
29
Uniontown, PA
Apr 5, 2011
#13
  • Apr 5, 2011
  • #13
Is it even possible to stuff 20's under the front fender on an 87?
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Apr 6, 2011
#14
  • Apr 6, 2011
  • #14
Edit: nope it's not
Flavadave4
1,044
21
49
Utica, NY
Apr 6, 2011
#15
  • Apr 6, 2011
  • #15
Any more pics of that car? It doesn't look bad in that pic.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Apr 6, 2011
#16
  • Apr 6, 2011
  • #16
I messed up...those are 18's
http://www.stangnet.com/mustang-forums/721214-19s-20s-fox.html
O
octaneforce
9
#17
  • Apr 6, 2011
  • #17
sorry for the misunderstanding. i looked at the car today. they rims are 17's w/ 255's. i dont know how i initially didnt think it was rediculous to have 20 inch rims on a fox. i just took what i was told and posted it.
Flavadave4
1,044
21
49
Utica, NY
Apr 6, 2011
#18
  • Apr 6, 2011
  • #18
I didn't want to call BS on ya...I was shaking my head this morning looking at that picture thinking "man those done look crazy huge like I thought"
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
