Silencer Removal +/-
A little sound difference? Yes. But you have to weigh this. The little bit of air coming from the little hole in the fenderwell is cooler air but not as much. Take the silencer off or the hole air filter cover, and you are getting all sorts of hot air from under the hood. Try it all and use what works best for ya.
JPD0244 said:
I did the same white stang. I heard removing it loses a lil. I just trimmed it at the other side of the fenderwell.
I did the same to mine, before the C&L MAF went in. Probably the best compomise to allow the best flow of air outside the engine compartment. Just a quick trick, with little or no effect. Don't expect anything over 1 HP.
mines out, and im glad i took it out. it wasnt fitting right with the BBK cold air induction... I tried to MAKE it work, and i ended up cracking the MAF (the cheap plastic housing around the airflow sensor).... so I said screw it, bought an intake (including a new METAL MAF housing), plenum, and filter (K&N) all from C&L and I couldnt be happier.... the tru-fit inlet tube ACTUALLY FITS GREAT! i couldnt believe it, something that actually works as it says it should.
