Simple 4 lug question.
  • Thread starter Thread starter MoneygrubbinCar
  • Start date Start date Apr 9, 2007
M
MoneygrubbinCar
155
Jacksonville
Apr 9, 2007
  • Apr 9, 2007
How well will the 4 lug setup hold up to makin a few passes at the strip? I'm a little worried about breaking wheel studs. I don't plan on running slicks I'd like to see mid 12's atleast but I didn't know if they would hold up to that.
goodfastncheap
100
Bellevue, NE
Apr 9, 2007
  • Apr 9, 2007
I've been advised before that I should be more worried about my 28-spline axles than the strength of the 4-lug flange. If your car is heavy and you launch hard enough to get in the mid 12's the 28-splines won't last. Just my opinion, I haven't gone that fast on my stock axles.
P
PJB
131
Rotterdam, NY
Apr 9, 2007
  • Apr 9, 2007
The statement that 5 lugs are stronger than 4 lugs is a load of BS.
I know a few guys that run 12's or better with stock 4 lug setups on stock axles with no trouble at all.
5 lugs swaps are done for the better brakes of the '94+ Mustangs and so you can have more wheel choices.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Apr 9, 2007
  • Apr 9, 2007
You'll be fine and good luck!
Strippt88
81
Cedar Lake, Indiana
Apr 9, 2007
  • Apr 9, 2007
Spent two years running 10 holers back in the early 90's, car ran 11.40's consistently, nary a problem!
M
MoneygrubbinCar
155
Jacksonville
Apr 9, 2007
  • Apr 9, 2007
Thanks fellas atleast thats one worry out of the way
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 9, 2007
  • Apr 9, 2007
if you are worried you can buy some upgraded studs.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 9, 2007
  • Apr 9, 2007
I don't buy this statement. Why would 1 ton vehicles and even bigger like your tractor trailer varienty have more lugs then 4. True I don't think that having 4 lugs is a bad thing but they definetally are not stronger then 5 or more lugs. That being said I upgraded my 4 Stud with ARP racing studs. They are much stronger. I to had worries about destroying my 4 stud with slicks on. But I don't worry bout it now.
M
MoneygrubbinCar
155
Jacksonville
Apr 9, 2007
  • Apr 9, 2007
Thanks again upgrading the wheelstuds themselves never crossed my mind sounds like a good upgrade for me in the near future.
smr
167
Nor*Cal (Vacaville)
Apr 9, 2007
#10
  • Apr 9, 2007
  • #10
if you run multipiece wheels most tracks require longer studs anyhow...its worth the extra couple of bucks and while you ar ein there pt on some c clip eliminators cause when/if you do break them stock axles you dont want to be the guy whos wheel and axle ran faster then him..seen it a bunch of times last year at sac....
4G-KDMP
935
CA
Apr 10, 2007
#11
  • Apr 10, 2007
  • #11
3 or 4 passes one behind the orther one you might have worries, but when was the lst time at the strip you had 3 or 4 passes one behind the orther one without some cooling down time?
LASTFOX
105
RI
Apr 10, 2007
#12
  • Apr 10, 2007
  • #12
5-lugs will allow for different wheel fitment and will help out if you plan to rally-race your stang. I'd put my money into something else
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Eastern North Carolina Autocross Events!
  • Warhorse Racing
  • Feb 23, 2026
  • Regional Forums and Event Information
Regional Forums and Event Information Feb 23, 2026
Warhorse Racing
