Simple compression ratio question
89roadster
1,124
Kent Island, MD
I'm in the process of building a new short block that will NA for a few years until I build the car I really want and add a turbo to the engine that I'm building now.
As long as there's not too much wear on the cylinder walls over the next couple years, will I be able to just replace the pistons and rings to acheive a lower compression ratio for the turbo? I know that I'll want a different cam and various top end accessories, but for now I'm mostly concerned about the short block.
I'm currently spec'ing everything out for forged internals in a 331/2 form. Any suggestions on rotating assemblies are appreciated.
Build it for boost now, the pistons will change from a flat top to a dish and you would need to have it all rebalanced.
A common 4cc flat top on a 331 will get you in the high 10.4-11:1 compression depending on your heads, a 14.2cc dish will get you in the 9-9.5:1 range, or a 22cc would get it even lower.
I was able to go mid 11's with 8.8:1 compression on a 302.
I forgot about the need to rebalance - good point.
The plan is to keep the Thumpers I have.
