skinnies on a 96 cobra
krr617
I would like to put 15x3.5's and 15x10's on my cobra. Can someone tell me what backspacing and/or spacer I need to fit a 15x3.5 around the front rotors, and if a 15X10 wheel will fit around the rear rotors? Thanks for any info!!
You can use a 1" or 1.25" H&R spacer on the fronts that will clear the brakes...I use a 1" with my 15x4" Telstars and they clear just barely without any grinding...
15x10" wheels will fit with a 6.5" backspace although I think you'll have to grind a bit on the caliper...I use 15x8" with 5" BS and I had to grind some for them to fit...
