If the diaphram in my adjustable fuel pressure regulator was bad and was leaking what would my a/f gauge show at cruising speeds? I'm brainstorming before I go check my vam and afpr in the morning pending dry weather.
Probably way Rich.Crovax said:If the diaphram in my adjustable fuel pressure regulator was bad and was leaking what would my a/f gauge show at cruising speeds? I'm brainstorming before I go check my vam and afpr in the morning pending dry weather.
howso? If it was leaking that would generally mean its not holding pressure, which would make it go leanDr_EluSivE said:Probably way Rich.
Dr.
Stinger said:I say rich as well...it WILL hold pressure, often times run even more pressure and it will also suck fuel into the engine via the vacuum line...
