Sloppy Hurst Competition Plus shifter?
  • Thread starter Thread starter DK832
  • Start date Start date May 28, 2006
DK832
291
Copenhagen, DK
May 28, 2006
  • May 28, 2006
When looking at my shifter on the side of the Toploader, there is a about 2-3 mm play alltogether in the stack of parts between the side and the backing plate. Hard to explain (didnt take a photo, doh!) but there are 3 lever arms made of stamped out plate, controlling a gear selector rod each, and about 3 spacer parts out of plate as well. Should all these "guts" be stacked tightly together or is 2-3 mm total space OK? If the space is not OK, what to do (short of replacing the whole unit)?
D
D.Hearne
11,730
south louisiana
May 28, 2006
  • May 28, 2006
Sounds about normal to me. They're not "tight" compared to the new car shifters of today, but a far cry tighter than the factory floor shifters were. You ought to have experienced the old "3-on-the-tree" column shifters. The distance the knob traveled from say, 1st to second was about 2 FEET Loads of fun to learn to drive. And even better once you mastered it. Nothing like taking it to the limit on a windey, sandy road. Like in the Dukes of Hazard movie.:SNSign:
HistoricMustang
2,359
Confederate States of America
May 28, 2006
  • May 28, 2006
Order the metal bushings and pitch the nylon that come with the kit.
A ton of difference in shifting!
http://www.ajusa.com/cgi-bin/stores...ajr_skey=19ee262ff6d438dcec94e53ce6cff562#q13
HistoricMustang
www.historicmustang.com/tech.html
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 29, 2006
  • May 29, 2006
Well Hurst has stamped that do not disassemble on the side of thier shifters.
But.....Mine was so stiff from years of build up that I took it apart anyway.
Lining all the parts on the bench to make sure it went back togeather correctly.
There is spring steel spacers inbetween the shift levers that keep them spaced. after cleaning them all off and using lithiam grease it is much smoother and seems tighter now.
Ps. Hm is correct get the Metal bushing set for the shift rods,
it will make shifting feel much more positive.
PB
DK832
291
Copenhagen, DK
May 30, 2006
  • May 30, 2006
Thanks everybody. I actually did take the Hurst apart, following the good write up from Mike at Toploaderheaven. Turned out to be quite clean and well greased in most places. Bushings and all was in the mail yesterday so that goes in today, then we'll see how tight it becomes.
DK832
291
Copenhagen, DK
May 31, 2006
  • May 31, 2006
I put in new selector arms yesterday as the old ones were widened out in the rectangular holes, they were kind of butterfly shaped (does that make sense in english?) and apparently allowed for some moving about. New bushings everywhere too and then an adjustment of rod length. Feels much tighter now; no looking for 2nd and no trouble getting 1st or 2nd after being in reverse.
Thanks for the input everyone!
:SNSign:
C
Hurst Competition Plus shifter question
  • chuck gibson
  • Feb 19, 2023
3K
Classic Mustang Specific Tech Feb 27, 2023
dennis112
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Progress Thread 88 Notched Fox
  • NotchedGarage
  • Jul 15, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2024
Flyboy60
F
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
