Sloppy Steering
dgw8022
22
My question is how can I fix the loose feeling with the steering wheel, I've tightened up the steering box as much as I feel it needs without causing binding. I know the Shelby drop has been mentioned before to give the car caster which should help.
I just want to know what has worked for someone else before I just start randomly changing things on the front end.
I have all new inner and outer tie end rods so that should be ok. No? I had the car on the ground and just popped the hood and adjusted the screw on top of the steering box?
Is their an actual method of adjusting the box?
Do you have manual or power steering?
I have the same problems with mine, I have PS.
I to tried adjusting the steering box like you while car was on ground
in a local parking lot doing 1/4 turns each try.
I wasn't aware either the car had to have the weight off the front end till I read D.Hearnes' post.
Here's a link to a members site here that might help in answering a few of your questions http://www.stangerssite.com/
