slow convertible top
1eo
Hey guys... my convertible top has no problem going down, but it sure needs a hand (or two) to get up :rlaugh:
is there a write up on how to change the motor?
what years share the same motor? (99-04? 94-04?)
thanks
Had the same problem here... then all the hydraulic oil leaked out from the tank. Now the top doesn't lift and go down by itself @ all.. I bet thats your problem. My car doesn't have a back seat or rear seat delete so i can see the pool of oil behind my driver seat .
Remove your rear seat and look for oil in the valley where the seat goes.
If you have money take it to a upholstery shop to get it fixed. I doubt its the motor. You probably have a busted line that is leaking oil.
Stop using your top till you know what the problem is. You can burn out your motor if its not the problem in the 1st hand.
GOod luck
Well, when I press the button the motor makes some noise and then slowly dies and stop making any type of noise. I can see the motor from the trunk ( I took the piece covering it). Once I get home, I ll check for oil
