There is a small leak in the cooling system somewhere. I've battled it for months now. I have replaced the pump. The car doesn't over heat(higher temp than normal) when driving normal. But minutes after the headlights are on or the A/C is running the temp goes in the "normal" but way to high zone. Even with it being full. Also I have flushed it three times with cleaner and still brown but not as dark.
I just put the UV dye into the radiator, trying to find my small leak. How long should I run this to find the leak? Any ideas?
Once I find the leak any idea on how to keep it cool when running the A/C?
Maybe a better coolant? Or one than claims it runs cooler?
Thank You for any help at all!
