SLP Loudmouths and Jet Performance Chip installed!!!
billy_tripper
56
I installed the Jet chip wednesday and immediately noticed an increase in throttle response. The change was not as much as I expected from the post in here before the crash, but it is definitely an improvement. I installed the SLP's this morning and wow, these things are amazing. I get a pretty good drone if I accelerate slowly to speed, but if I drive like I normally do, I get an awesome growl. I couldn't be more pleased with them. There is no popping whatsoever and they were really easy to install. The hardest part was getting the stock mufflers off because some of the bolts to the hangar brackets are hard to reach, but once I got them off the SLP's install EASILY because they don't have a muffler and you can easily get to all the bolts. I am annoyed at how the right one hangs down lower but I'm going to work on that. I believe I can bend the hangar a little in my dad's shop. I'll let you all know if it works. Someone else mentioned that you can have someone pull up on the pipe while you retighten the bolts, but someone else said it would work it's way back down, so I'm not sure about that method. It's not real noticeable though. If you want a good sound, this is the way to go. They are loud, but deep at the same time. They sound absolutely amazing under full throttle! My gas mileage is going to go way down listening to these babies.
I got the Jet chip from rpmoutlet.com. It was 209 after shipping.
I got the SLP's from LMPerformance and they were 225 with free shipping.
