small question about timing
  • Thread starter Thread starter dragnazz5.0
  • Start date Start date Feb 12, 2006
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Feb 12, 2006
  • Feb 12, 2006
hey, i got my car all back together and got it timed at 10* btdc. and with the spout out the timing light flashes at 10*, but once i put the spout in the timing light flashes at 30* btdc. is that right? or should it still be flashing at 10*?
HISSIN50
34
129
Feb 12, 2006
  • Feb 12, 2006
That seems a hair high, but in the rough ballpark. I get about 15* advance from installing the SPOUT on the '94, but I dont recall how much the fox bumps it up.
It certainly should not remain at where it was with the SPOUT out. I would have expected closer to 12-15* advance from installing the SPOUT alone.
joel5.0
429
Puerto Rico
Feb 12, 2006
  • Feb 12, 2006
Once you reconnect the SPOUT, the ECM takes over timing control, which is higher than the base setting of 10° = it's normal. I would check the timing @2500 RPM and see if it goes over 35°.....LUK
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 12, 2006
  • Feb 12, 2006
its just been so long since ive done the timing on my car and i couldnt remember if it did that. thanks guys
C
ColdAudio
31
  • Feb 12, 2006
hmm my car seems a bit sluggish and this is an interesting point... what is the amount increase in timing i should be looking for with the spout in after setting base timing with the spout out? also, what does it mean if the timing doesn't move much at all? thanks.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 13, 2006
  • Feb 13, 2006
I'm not sure, but make sure your distributer isn't a tooth off, this is a common issue, the distributer being a tooth off being able to be adjusted to spec but then it's at the peak of it's adjustment.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Feb 13, 2006
  • Feb 13, 2006
the distributor is put in correctly. i guess i never really checked it with the spout in.
Luis911
114
Mexico City
Feb 13, 2006
  • Feb 13, 2006
I have problems whit timing, don't have SPOUT only one bridge, what is the value of resistence on ohms?
Thanks
onefstsnake
792
Northern VA
Feb 14, 2006
  • Feb 14, 2006
well i set my timing today.
14* without the spout and about 24* with the spout.
Seems low...
I also set the TB voltage to .97 any higher and it would idle higher.
And I cleaned the MAF sensor
joel5.0
429
Puerto Rico
Feb 14, 2006
#10
  • Feb 14, 2006
  • #10
Thanks
None.....0 ohms the SPOUT is a bridge/jumper connector...as long as it is protected from getting shorted to other wires/components around, that shouldn't be a problem. In your case, what is the timing problem you have?...
joel5.0
429
Puerto Rico
Feb 14, 2006
#11
  • Feb 14, 2006
  • #11
Seems low...
That's the normal "jump" for the system @idle (20°-24°), it goes over that with an increase in RPM's...check it @3200 RPM, it should go near or over 40°. LUK
onefstsnake
792
Northern VA
Feb 14, 2006
#12
  • Feb 14, 2006
  • #12
yea it doesnt go above 34-36*
sgarlic
3,085
Feb 15, 2006
#13
  • Feb 15, 2006
  • #13
You're good.. I asked the same questions first time I re-timed my '88. Seems crazy to see it bounce around and run fine when it was running fine at 10* with the spout off huh?
onefstsnake
792
Northern VA
Feb 15, 2006
#14
  • Feb 15, 2006
  • #14
yeah it was really getting wierd when I was adjusting the TB voltage...
Luis911
114
Mexico City
May 15, 2006
#15
  • May 15, 2006
  • #15
only a bridge/jumper??????? $7.00 dlls . My timing poblem is high RPM, I think I have other problems, I buyed a spout
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
