EscortLXSport New Member May 5, 2003 28 0 0 Franklin, NC Aug 1, 2006 #1 Aug 1, 2006 #1 I did already hooked up with MAC Header, H-Pipe, and Cat back system Is it normal?
T TENGRAM New Member Mar 18, 2006 143 0 0 Aug 1, 2006 #2 Aug 1, 2006 #2 it could be anything really. your best bet is to Check for Codes
QDRHRSE New Member Dec 31, 2002 1,590 0 0 Palmdale, CA Aug 1, 2006 #3 Aug 1, 2006 #3 Codes are good I suppose. You are obviously running rich. How many miles? O2's maybe?
Lash New Member Jul 19, 2006 36 0 0 Pewaukee, WI Aug 1, 2006 #4 Aug 1, 2006 #4 Could be a bad FPR. Sometimes they'll develope a tiny leak.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 1, 2006 #5 Aug 1, 2006 #5 Could also be the charcoal cannister or purge line (the latter is known for cracking). You'll get a nice whiff of fuel smell if the system is open. Good luck.
Lash New Member Jul 19, 2006 36 0 0 Pewaukee, WI Aug 1, 2006 #6 Aug 1, 2006 #6 HISSIN50 said: Could also be the charcoal cannister or purge line (the latter is known for cracking). You'll get a nice whiff of fuel smell if the system is open. Good luck. Click to expand... Yeah....that too.
Foxfan88 My Grandpa has great wood. Sep 13, 2004 2,487 4 0 Miami, Ok Aug 1, 2006 #7 Aug 1, 2006 #7 do a good check for leaks around the FPR and the rail and the lines going down. get your face down and take note if the smell gets stronger in a certain area...
EscortLXSport New Member May 5, 2003 28 0 0 Franklin, NC Aug 1, 2006 #8 Aug 1, 2006 #8 nevermind fixed it thank
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 1, 2006 #9 Aug 1, 2006 #9 And the solution was...................??
