My bad....
by the way, all of this commentary was for my old 87 5.0 lx stang that "passed away" a few years back <sheds a tear>
now,
I was operating under the assumption that the spent gasses are at exhaust temperatures: the same ones that burn 1500 degree ceramic paint off my headers. I cannot imagine that any byproduct of a combustion porcess would end up at less than atmospheric temperature (though there are strange laws of physics at work inside motors...like exhaust pulses that pull spent gasses OUT of the combustion chamber.). In my defence though, I was told the coolant is run to the TB to offset the extra temps from the egr so that led me to believe that the charge is hot.
I had blocked off the egr passage in my EFI with a cobra spacer that did not have the egr passage drilled. No negative effects. Maybe the EEC offset the appartent higher exhaust temps from the lean condition caused by extra air. It would be reported by the O2 sensor with an adjustment factor that richened the mixture a bit. Isnt that what the O2 is there for? Constant tuning? The EEC is supposed to adjust for the operating conditions and tune the engine as it ages and becomes less efficient. Even a speed density stang should be able to make such a basic adjustment I think.
I guess I was wrong about the little canister though. The passage behind it when removed looked _black_ with soot. Exactly the same as egr passage so the assumption was made.
Now the PCV definatley has no benefit to pump into the intake stream, of this I am sure. I have the pcv hose hooked to the pickup on the underside of the carb's dish aircleaner and you could see a brownish black streak from the hose's port torwards the carb as the vaporized oil reenters the engine. All this would do is gum up the intake, foul plugs and increase tailpipe emissions with the extra burning carbon.
At inspection time, I'm rolling with stock 4-cats, airpump to crossover , egr/pcv spacer plate hooked to hoses and charcoal cannister in stock location with tube run to aircleaner. Granted the last time I got it inspected, I had sneaky tubes dumping crankcase gasses into the fender, the h-pipe's airtube sneaked out the side, airpump with alternator pulley filling the exhaust pipes with fresh air and the carb crazy tuned to stoich, secondary side disconnected and a 3.5 power valve. When you go carb, you plan to do a little sneaky stuff at inspection time.
Maybe I should get a fake efi intake I could slide over the carb and some fake OEM wiring bundles I could toss on top of the engine and some hoses.
They dont strain themselves doing the visual inspection around here. As long as the tailpipe says what the machine wants to hear, everone's cool as long as your blinkers and wipers work and the wheels dont fall off while you're there.
