Hello all. I've been doing some research on this and got quite a bit of information but still have a few ?S that I did not see addressed. I am going to remove all the smog equipment EGR included. I found a cap that fits the header tube so that is taken care of.
1. Can I just leave the smog pump on and plug (cap off) the hole that the hose is connected to? Will there be a negative affect from pluggin the smog pump hole vs. just removing the smog pump. BTW, I do not want to use a short belt. So it will be this method or a smog pump delete kit.
2. I know the bolt needed to plug the holes in back of the heads size is 5/8-11 but what is the proper length bolt to use. The smallest bolt I can find is a 5/8-11 1" long bolt. Will this fit or is it to long? I prefer to use a bolt instead of the insert with the slot just in case I have to remove the bolts and reinstall the smog stuff to pass emission.
Thanks for any help.
Al
Al
