smog pump effect?
  • Thread starter Thread starter GTPhreak
  • Start date Start date Jan 19, 2004
GTPhreak
5,505
Rowlett, TEXAS
Jan 19, 2004
  • Jan 19, 2004
how much of an effect does the smog pump have on emissions? Reason I ask is I have to go through emissions testing, but my smog pump siezed up, so I want to go ahead and just remove it. who out there is passing emissions without a smog pump?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jan 19, 2004
  • Jan 19, 2004
You will pass the sniffer fine.
R
raph130
517
  • Jan 19, 2004
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 19, 2004
  • Jan 19, 2004
If your inspection protocol calls for a visual inspection, there's a reasonable chance they'll notice that it's missing. It's almost impossible to predict whether you'll pass the sniffer or not. Testing procedures vary even from county to county within the same state, let alone from state to state. Kind of humorous that someone from Massachusetts is telling you you'll pass in TX -- the tests, equipment, training of techs who perform the tests are different everywhere you go; not to mention each vehicle is unique. Passing in one area is no guarantee that someone else will pass elsewhere. I've seen posts from people with stock cars in good working order with all smog equipment present that failed, and then you've folks like those above that indicate they've passed with emissions equipment missing. Best thing to do is to find out exactly what they techs that do the inspection are looking for before you take it in for the test. If they do a thorough visual inspection and the pump's not there - well, you can figure that out.
The pump is designed to supply excess oxygen to the exhaust stream so the cats can 'catalyze' the chemical reactions needed to turn unburned hydrocarbons, NOx and CO into non-controlled emissions. Certainly if you don't have cats there's no reason to run the air pump. And the cats won't work as well if you have them, but you're missing the air pump - they're designed to work together.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
T
Engine Broken Smog pump bolt
  • townethug
  • Jun 14, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
limp
