smog pump ?
  • Thread starter Thread starter rudy herrera
  • Start date Start date Nov 17, 2010
R
rudy herrera
110
Nov 17, 2010
  • Nov 17, 2010
my smog pump ceased yesterday night i need to buy one when i was looking for it i found the one that deletes it but thats just the pulley how does that work wat would i need to do all so how hard is it to take the smog pump of
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Nov 17, 2010
  • Nov 17, 2010
I'd just pull it off all together assuming you aren't required to have it for inspection. Should only be two or three bolts and then the hose. You'd either need to plug the hose off, or remove the rest of the air injection system TAV/ TAB valves, cross over tube and air pipe.
fordmuscle395
114
Sumter, sc
Nov 17, 2010
  • Nov 17, 2010
and if you don't wanna do all of that I can send you mine. I pulled all my smog stuff off
BYRDPE
1,556
Memphis,Tn.
Nov 17, 2010
  • Nov 17, 2010
if the op doesn't take you up on this offer, i will. pm me and let me know what you want for it.
fordmuscle395
114
Sumter, sc
Nov 17, 2010
  • Nov 17, 2010
copy
Maryland Stang
1,656
30
39
Greenville, NC
Nov 18, 2010
  • Nov 18, 2010
You guys do know that you can buy these pumps at the auto parts stores right?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Nov 18, 2010
  • Nov 18, 2010
Or you can replace the bearing in them. It's a common bearing. I rmoved mine, googled the bearing, bought one for $10 online and had a working pump again
R
rudy herrera
110
Nov 20, 2010
  • Nov 20, 2010
my friend had a 85 smog pump and i was wondering if it will fit my 1990 mustang
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
  • Mindseye007
  • Aug 16, 2026
Mindseye007
