Engine Smog system Q
Thanks for the insight.
Previous advice in this site mentioned:
“The best thing to do is to put a cap on the diverter valve or plug in the hose where it comes off the diverter valve to the crossover pipe.”
this was to avoid having “smog pump air to pass into the heads or the hpipe,if converters are no longer present,because the extra air might get measured by the O2 sensor's,causing a lean signal.”
how do u keep it hooked up I'd have to run a long tube to my h pipe the metal tube got cut to short
