Smoke at WOT
94IVGT
36
Illinios
Smoke at WOT
94 GT 5.0l
less than 1000miles on motor
moly rings
vortech s/c 8lbs
new twisted wedge heads
cometic mls headgaskets
140psi on all cylinders dry test
no smoke on startup or cruising
is this normal at wot? what would be the cause of this?
moly rings are Very hard, and can take i lil while to seat, and if the cylinder walls were not properly "hatched" when the rebuild was done they may never seat. As far as the valve steams seals I believe that would create more of a smoking at start up and take off, I'm not sure tho.
check to see if the pcv valve has popped out...or if the dip stick has popped up. When I had pcv issues, the pressure would cause the dipstick to pop up and oil would squirt out from there onto the headers. Making it look like my engine blew up every time I'd floor it. It could also be a bad intake manifold seal.
