Smoke from breather
  • Thread starter Thread starter COramprat
  • Start date Start date Feb 14, 2013
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 14, 2013
  • Feb 14, 2013
This is a 66 with a 250 inline. It has a breather oil cap and a PCV valve but it isn't hooked to a vacuum. I'm getting a lot of smoke from the breather and when I pull the PCV it stops and comes from the PCV bung. Any ideas what could be causing this? Just has power steering and AC kit installed but I'm not sure if it is related.
horse sence
8,413
233
Wile Coyote's stunt double
Feb 14, 2013
  • Feb 14, 2013
the pcv valve allowes the vacume created by the motor to draw presure created by the pistons and rotating assembly out of the crank case with out causing an open vacume leak . it has to go some were ,with out the pcv valve hooked up it goes out the breather cap. and can cause seal failure. but if you are seeing smoke from the breather cap you probably have piston ring blow by /worn rings .
bartl
217
West Rutland, Vermont
Feb 17, 2013
  • Feb 17, 2013
Smoke from the breather is combustion blow-by. Some amount can be expected and this is the purpose of the PCV valve, to create a vacuum in the crankcase to funnel the vapors back into the intake stream to be burned. The PCV valve reduced hydrocarbon emissions by about 95% and was, and has been, the single most effective pollution control ever installed on the automobile engine. The side benefit is that along with combustion blow-by it also removes moisture from the crankcase greatly extending oil life and preventing sludge. You should reconnect the PCV to a manifold vacuum source as soon as possible.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 7, 2013
  • Mar 7, 2013
I think I will. Just have to find a vacuum source. Does anyone know where it was originally on a 250?
Iamdiffrnt
197
South of Detroit, MI
Mar 7, 2013
  • Mar 7, 2013
Generally most engines either use a carb spacer with a hose connection, or one on the intake.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
