smoke
  • Thread starter Thread starter wht99gtconv
  • Start date Start date Nov 19, 2006
W
wht99gtconv
267
  • Nov 19, 2006
Whats up fellows? Im usually on the 4.6 fourm cause i have a blown 99gt, but now i have to stangs. I bought a 87gt the other day and it smokes. Could any of you tell me if it may needs rings or just put thicker oil in it.
RYC CUKR
1,437
Orlando
Nov 19, 2006
  • Nov 19, 2006
what color smoke? Black generally means running rich, blue is oil and white or steam is coolant
I would run a compression test and see what number you come up with. Then squirt some oil in each cylinder and see if the number just up a good bit. If they do then more than likely your rings are worn. By adding the oil it helps the rings seal and can hopefully point you in the proper direction of where you are loosing compression. You might also want to do a leak down test as well and see what the results are.
W
wht99gtconv
267
  • Nov 19, 2006
Is it hard to replace the rings
W
wht99gtconv
267
  • Nov 19, 2006
The oil pressure goes down just idleing but when i press the gas to go it goes up.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Nov 20, 2006
  • Nov 20, 2006
Thats normal, what kind of miles does it have on er? I know mine smoked a little, I took it out one day, started makin rod knock, then I pulled the engine to find that there were 9 piston skirts in the pan, along with about all the rings, it still ran good, just smoked with a clanking noise LOL. This is not typical at all, as most lincoln town cars you see smoke, and still run fine. But it would be best to rebuild the shortblock, running thicker oil is just a band aid to the prob.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
