SN95 5 Lug Swap Info needed
roadrunner19va
63
I know this has been beat to death. But will the rear axles fit into a fox rear end. I know the rear brake drum will not line up correctly but how hard is it to change the rear drum brakes from a fox to the SN 95 rear disc brakes? will the whole rear end from a SN 95 bolt up to the fox? I really want to do a 5 lug swap but all of the articles I read do not make a lot of sense to me. Any info on this swap would be appreciated. Thanks Travis
the entire rear end will bolt right in, thats the easy part, its the front thats more difficult and you ahve to swap the brake master cyclinder and proportioning valve or your car wont stop properly
good luck
