Sn95 Conversion Tie Rods...
  • Thread starter Thread starter G00nies
  • Start date Start date Feb 4, 2017
G
G00nies
149
Feb 4, 2017
  • Feb 4, 2017
Have my 1995 spindles installed on the fox, cobra brakes and calipers. HOWEVER, the un-anticipated issue is the extreme toe adjustment required..after installation
Do I need to replace inner/outer tie rods?
Bumpsteer kit?
Need an assist...thanks
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
Feb 4, 2017
  • Feb 4, 2017
Have you read the tech thread on five lug swap? I just skimmed over it, I like my black pony wheels too much but am thinking of building a road course car.
Maybe @Mustang5L5 will chime in.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Feb 4, 2017
  • Feb 4, 2017
That's normal, and to be expected. Adjust the tie rods to get the wheels as straight as you can, and go get an alignment. No need to swap parts here just make sure you have plenty of thread engagement.
G
G00nies
149
Feb 4, 2017
  • Feb 4, 2017
Will Do>
I DID find that a 1995 INNER tie rod end is 2 inches longer, fitting it now
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
Feb 4, 2017
  • Feb 4, 2017
Did you read post #3?
What is the problem your having not enought threads?
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Feb 4, 2017
  • Feb 4, 2017
G00nies said:
Will Do>
SN95 tie rods are metric, while fox is sae thread. Problem is if you use the sn95 outer tie rods, you will run out of thread before you can thread them in far enough to get wheels straight
I believe 93 Ford Taurus outers are metric and shorter and will work.
Or simply thread out your currrnt tie rod ends. That's all I did
Are you out of thread if you turn them out?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 6, 2017
  • Feb 6, 2017
Just turn the Stock Outers out to get close enough to take for an alignment.
Suspension Tire screeching after shorter endlinks and tie rod ends?
  • RotFox90
  • Apr 13, 2024
Fox 5.0 Mustang Tech Apr 14, 2024
RotFox90
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SN 95 rack in Fox body
  • Va89Stang
  • Feb 16, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2024
Mustang5L5
