sn95 ecu on aod ?
  • Thread starter Thread starter lincoln+ford
  • Start date Start date Aug 15, 2009
lincoln+ford
195
  • Aug 15, 2009
Im converting my car speed density aod to mass air but the only ecu i have to try is a sn95 5 spd ecu is there anything that can cause harm using a 5spd ecu on aod vehicle its a 91 the ecu is going into.
95Vert383AOD
1,133
34
69
New Bedford, MA
Aug 15, 2009
  • Aug 15, 2009
Nope shouldnt be a problem. Do you have a T4MO? You would really be better to find a A9L or A9P if its going into a 91. I assume its a Mark 7....i've built up a couple of these and have done the mass air thing a couple of times. Heck i even have a 3" Cowl in my garage from when i tossed the 383 in one.
lincoln+ford
195
  • Aug 15, 2009
yep its for the mark VII.whats a T4MO the ecu code?Actually its my buddies and i know he still has it i just want to get my car running today.Cuz i didnt tap the intake manifold for the speed density sensor whatever it is on the #5 cylinder.Got any tips for doing the mass air conversion?
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
ECU help!
  • starkiller1134
  • Aug 16, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
