SN95 F.A.S.T install
never used F.A.S.T. but it does seem nice. Check out the AEM EMS system. Its a standalone setup that will plug into the factory harness and use all the original sensors or you can remove them, mix and match, just whatever. I will get an AEM EMS one of these days when I have enough power to warrant it. I think its a little cheaper than the FAST also, and pretty user friendly
Redsnk95 said:
Well what questions do you have?
Troy
First my FAST system came off of a fox body car, but on there web site, they do not seperate the kits, so this should work on the SN95's without to much changes, I hope..lol
Well the first question is, What distributer did you use, your stock one or did you go with an aftermarket? I have my Stock distributer with an MSD 6AL box and an MSD Blaster coil, but on the FAST harness, the wires look different.
What did you do with the three sets of wire harnesses that sit right in front of the stock ECU? What are those 3 harnesses for anyways?
Are you running just the FAST harness? If so do your stock dash guages all work?
I have more but these are the initial ones.
Thanks,
Will
