Snap Crackle Pop
  • Thread starter Thread starter JOHNSUAVE
  • Start date Start date Nov 6, 2005
J
JOHNSUAVE
Tucson
Nov 6, 2005
  • Nov 6, 2005
I have a standard 66 coupe (no mods)with the 6 cylinder engine. I have been having a problem with the plugs popping off while the engines running (usually when I start it)I can hear the popping sound and it immediately begins to loose power. Once I reconnect the plug it runs fine, I was told that I should get a new carburetor and that would solve the problem and lead to overall better performance. What types of carbs do you guys have and would you suggest rebuilding the existing carb or just buying a new one. Would this also help with starting the engine, usually wont start until 4th attempt now that its colder
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Nov 6, 2005
  • Nov 6, 2005
OK I give up. What are you calling "plugs pop off"
do the wires come off or are the plugs poping out of the head, WHAT
tos
896
68
59
Cincinnati Ohio
Nov 7, 2005
  • Nov 7, 2005
I was wondering the same thing. Maybe vacuum port plugs? I've seen cars with the timing so far advanced they would backfire thru the carb and blow the vacuum plugs off. Is that what your refering to as plugs?
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 7, 2005
  • Nov 7, 2005
Sounds like he's got it cross wired possibly. Check the firing order.
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
