Snapped intake bolt!
  • Thread starter Thread starter Na5.0HO
  • Start date Start date Mar 8, 2004
N
Na5.0HO
342
Michigan
Mar 8, 2004
  • Mar 8, 2004
Quick Background: I just got a ported and polished Edelbrock Performer 5.0 Intake, BBK 65mm TB and Spacer, BBK Longtubes and off road H - Pipe from a buddy for 500 bucks and my stock 'Kiss Me''Kiss Me''Kiss Me''Kiss Me'...
Problem: Intake has a snapped bolt (upper to lower)which he ran with and had no problems but I dislike.
I bought an Easy Out tool and everything seemed fine until it snapped in the hole I drilled. Now I have the Easy out stuck in the bolt, which is stuck in the intake!! and everything is flush so I can't try to get a grip on it.... Now I can't seem to drill another hole cause the Easy Out is too hard...
I'm broke after the 500 dollars, but it was an offer I couldn't refuse... so what should I do??
Thanx, Jason
N
Na5.0HO
342
Michigan
Mar 8, 2004
  • Mar 8, 2004
Sorry for double post... Computer froze... and I don't know where "kiss me, kiss me" etc. came from
RYC CUKR
1,437
Orlando
Mar 8, 2004
  • Mar 8, 2004
Is the intake on the car?
If not I would find a machine shop and see how much it would cost to have them take the bolt out. I wouldn't think that it would be that much maybe $30-$50. That is the only idea I have. Wish I had one that didn't involve more cash but at this point I think thats about all you can do.
N
Na5.0HO
342
Michigan
Mar 8, 2004
  • Mar 8, 2004
The intake is still currently off the car...
TK_05
286
Las Vegas
Mar 8, 2004
  • Mar 8, 2004
uhh the easy out should twist out... if not i dont know what to tell you... i would take it to a machine shop and not cause further damage because the intake and stuff are aluminum
N
Na5.0HO
342
Michigan
Mar 8, 2004
  • Mar 8, 2004
Looks like I'm going to have to dig a little deeper into my already shallow pockets and find a machinist... Thanx for the advice guys
RYC CUKR
1,437
Orlando
Mar 8, 2004
  • Mar 8, 2004
I know how you feel.
I crushed the injector wiring harness when I put my intake on. Talk about a pain trying to find out what was bad.
But like I said take it to a machine shop. They should be able to fix it right up.
P
PRO50SC
1,012
Olney, Maryland
Mar 8, 2004
  • Mar 8, 2004
If you have ever broken an easy out in a bolt you would know they're almost impossible to get out. This happened to me once and I used a very sharp pointed pin punch and a hammer and was able to chip away and break up the easy out inside the drilled hole. A machine shop is definitly a great suggestion if you are lacking tools or experience in this area. The aluminum is very soft and easily damaged. Good luck!!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 8, 2004
  • Mar 8, 2004
You may just end out having to drill it out and put a helacoil in.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Mar 8, 2004
#10
  • Mar 8, 2004
  • #10
yep, happened to one of my friends...he used an air hammer to get the easy out off and than drilled it out and used a helicoil. but his bolt snapped off in the block on the bottom side of the timing chain cover.
N
Na5.0HO
342
Michigan
Mar 8, 2004
#11
  • Mar 8, 2004
  • #11
I'm thinking of just running it without the bolt for now until I can get some ca$h.. since the previous owner ran it with only 4 of the 6 bolts and had no problems. What IS a helacoil neways?
Thanx
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 8, 2004
#12
  • Mar 8, 2004
  • #12
Thanx
Sorry, I spelled it wrong, it's helicoil and it's this....
http://www.hillcliff-tools.com/helicoil.html
N
Na5.0HO
342
Michigan
Mar 8, 2004
#13
  • Mar 8, 2004
  • #13
Ah... thanx for the info.
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Loose connection near the back of the alternator wiring harness
  • 1996 Stang GT
  • Sep 5, 2025
1996 Stang GT
Leaking top of intake
  • Bertan
  • Jan 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 17, 2026
manicmechanic007
R
Electrical Act
  • Robman8028
  • Jun 15, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
General karthief
