It can be a pain, but heat and vise grips can get it done. You could even use a stud remover that Advance Auto sells relatively cheap.
Heat will give you the best chance of not breaking it again in a worse spot.Thanks Joe, I'm hoping to avoid breaking out the torch. I'll check out the stud remover.
Damm dude, I just went through this just over a month ago. Exact same issue, but I snapped 2 on my drivers side. I ended up having to pull my timing chain cover off in order to get them out. Here is the link to my thread: http://www.stangnet.com/mustang-forums/threads/water-pump-nightmare.864763/
Is the propane I have for sweating copper even worth trying, or go right to MAPP?
...), I'm back at it this morning, will post progress.I still prefer a 10" pipe wrench over a pair of viceie grippies.
Got it, with PB, propane, 2lb sledge, stud remover from advance, and I'm sure more than a little luck.
Now to put it back together, new stat and all. Thanks everyone.
Smart man - he knows that he will have to do it again if he keeps the car for a long time.Please tell us you put anti seize on the new bolts and chased the threads with a tap.![]()
