Ok lots of threads regarding snow and tires recently, but most involve what to get. I don't have the money right now to get a set of old rims with blizzaks so that's not the case for me.
I wanna know about how many pounds of weight I should put in the trunk?
And "like" how do I control my car if it goes and spins on turns or anything. This is my 1st RWD car so I have no idea what it feels like and I'd like to be prepared as best as possbile. If someone can draw out a scenario and explain it, it would be greatly appreciated.
Thanks guys, and to all you lucky Florida or Cali Stangeres, damn YOU! LUCKY!
), brake early and as lightly as you can get away with, maintain a longer distance between yourself and the car in front of you (who cares if someone is honking behind you--let them pass you and crash into someone else's trunk), avoid sharp turns unless you are moving slowly. If you are beginning to skid sideways, keep your feet off both the gas and the brake, and steer in the direction that you would like to continue going. For example, if your car's back end starts sliding to the passenger side, steer right. If it starts sliding to the driver's side, steer left. Also, start off in second gear if you need to--it's OK to do that from time to time.
