So After A Few High Speed Runs My Car Runs Really Rich???
NXSTANG
18
SoCal
Well after a few races My car is running Fat It stalls and pops thru the Exuast.While I was racing My Check Engine Light came on for a couple seconds but It hasn't came back on.I recently Replaced the ACT sensor and Coolant Temp Sensor I checked my Timing and Fuel Pressure and they are fine.Were should I start Looking?
YOu just asked a question for your own response... "Running Rich" , "Where to look"????
Fuel + Where to Look = Fuel lines, A/F Ratio settings. Make adjustments by rasing the A/F
It was running fine for about 6 months with no tune just messing with FP and Timming.Ok So I Scanned for codes and Got KOEO 34,67,85 and KOER 34,13,12,92 what do you think my Problem could Be?
KOEO Codes:
34 - PFE or EVP circuit above the closed limit of 0.67 volts.
67 - Neutral safety circuit failure.
85 - Canister Purge Solenoid circuit failure.
None of those you need to be too worried about at this point.
KOER Codes:
12 - Cannot control RPM during ER Self-Test high RPM check.
13 - Cannot control RPM during ER Self-Test low RPM check.
92 - HEGO sensor circuit indicates system rich (left side).
Obviously, the left bank is rich all the time, and that is where you need to start looking. How are your plugs?
well looks like you have a IAC issue perhaps and it says your system is running rich. Perhaps you have a O2 sensor issue. Don't go spending money on these parts just yet. When you say it is running rich is that at idle or all the time?
Thanks for the Replies It runs rich ALL the time I cant even drive It I pulled the plugs and they are all a dull black Th IAC is about 3 months old and the o2 sensors are about 1yr1/2 but They have had there fair share of Nitrous runs.
well perhaps the o2 is the problem but maybe not. Have you checked the psi of your fuel rail? did something get bumped? You say you have nitrous is there any chance that the fuel solinoid on the nitrous system stuck open and that is the extra fuel you are getting?
Testing the O2 sensors
Measuring the O2 sensor voltage at the computer will give you a good idea of how well
they are working. You'll have to pull the passenger side kick panel off to gain access to the
computer connector. Remove the plastic wiring cover to get to the back side of the wiring.
Use a safety pin or paper clip to probe the connections from the rear. The computer
pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire).
Use the ground next to the computer to ground the voltmeter.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are
disconnected and measure the resistance from the O2 sensor body harness to the pins
on the computer.
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Do not attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for
the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the
other one probably isn't far behind.
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck open
Do a cylinder balance test: Warm the car's engine up to normal operating
temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to
put the computer into test mode. Start the engine and let it go through the
normal diagnostic tests, then quickly press the throttle to the floor. The
engine RPM should exceed 2500 RPM's for a brief second. The engine will shut
off power to each injector, one at a time. When it has sequenced through all
8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for
cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause
the test to re-run with smaller qualifying figures. Do it a third time, and if the
same cylinder shows up, the cylinder is weak and isn’t putting out power like
it should. See the Chilton’s Shop manual for the complete test procedure
The red wire on each injector is powered up whenever the ignition switch is
in the Run position. The computer provides a ground to complete the circuit
and fire the injector. The injector must have a ground to squirt fuel on
command. A short to ground in the injector return wiring can cause one or
more injectors to be continually open or triggered
A.) A Noid light available from Autozone, is one way to test
the injector wiring. If the light stays on constantly, either the wiring has a
short to ground or the computer has failed
B.) I like to use an old injector with compressed air applied to the
injector where the fuel rail would normally connect. I hook the whole thing
up, apply compressed air to the injector and stick it in a paper cup of soapy
water. When the engine cranks with the ignition switch on, if the injector
fires, it makes bubbles An injector stuck open will release a continual stream
of bubbles. Cheap if you have the stuff laying around, and works good too.
The same trick works great to find leaking injectors too.​
The wiring for the injectors may have some bare spots in it causing the
injector to computer control wire to ground out. This would cause the
injector to remain on anytime the key was in the Run position. Remove the
injector wiring connectors from the injector. Note that each injector has one
red wire for power and a non red wire (wire some color other than red) for
computer controlled ground. With the key off, disconnect the computer
connector from the computer. Use an Ohmmeter between the non red wire
and ground. You should see more than 100000 (100K) ohms resistance.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help wiring http://www.veryuseful.com/mustang/tech/engine/
Using the above diagram, check the resistance between the injector and the
computer. Clean and check the 10 pin connectors since they are a potential
trouble source. Any resistance greater than 1 ohm between the injector to
computer wire and the matching pin on the computer connector is a problem.
See http://fordfuelinjection.com/?p=6 for more help
