• Community Forums
  • Regional Forums and Event Information
So close...
  • Thread starter Thread starter Vortech88GT
  • Start date Start date Jun 22, 2006
V
Vortech88GT
Seattle
Jun 22, 2006
  • Jun 22, 2006
I cant believe it... I'm trying to crack the 12s with the combo in my sig (stock motor, 5-6psi, FMU, 10* base timing spout in) before I start trying to maximize my combo and start adding the parts I've been accumulating. Last night at the Pacific Raceways TNT out of 4 runs I had three 13.0X runs...
I'm running MT 235/15 DRs with smokey 2nd gear burnouts. I have been messing around with tire pressure and launch RPMs. Last night I was trying between 16 and 18 psi.
First run I blew the tires away on a 3500RPM launch to the tune of a 2.3 60'. I have never had them go up in smoke that bad before which really screwed me up for the rest of the night...
Second run I was trying not to waste another run going up is smoke again(especially after waiting over an hour for "the sun to go behind the trees") so I dropped my RPM to about 3250. This time I bogged bad and pulled a 1.960 60' for a 13.02 ET at 107.5mph.
Third run I upped the RPM to about 3500 again (should have gone higher but I didn't want to waste a run) and bogged even worse to a 1.964 60' for a 13.03 ET at 107.9mph.
Last run I decided to try a 4000 RPM launch and slip the clutch a little more than I had been. Bogged the worst yet to a 1.969 60' for a 13.09 ET at 107.3mph. I blew off a vacuum line somewhere at some point on that run and it was already dark so I couldn't find it. So that became my last run.
Man.. I was so close. Last time out I pulled a 1.8 60' (weather was worse though so my trap was down and ran a 13.06). If I could have hit one of those last night I would have been all over the 12s but that first damn run screwed me up.
Didn't make my goal but at least I was consistant (even though I really didn't want it to be)... three back to back 1.96 60' runs all with 13.0X ETs and 107.X mph.
WaterPog
2,201
Portland, OR
Jun 22, 2006
  • Jun 22, 2006
How low have you tried dropping the pressure? On my car I've had the best luck around 12-14psi.
V
Vortech88GT
Seattle
Jun 22, 2006
  • Jun 22, 2006
16 psi is as low as I've gone so far. I have heard that you shouldn't go too far below 16 with as much weight as I'm pushing on 235s.
WaterPog
2,201
Portland, OR
Jun 22, 2006
  • Jun 22, 2006
give it a try, it can't really hurt anything, with as little power as you're making you're going to need to get it out of the hole to get the times you're after.
Warbird19
742
Washington, Federal Way
Jun 22, 2006
  • Jun 22, 2006
That sucks man i saw your third run and thought for sure you were going to get a 12.9x time. well good luck next time, and thanks for the air.
V
Vortech88GT
Seattle
Jun 23, 2006
  • Jun 23, 2006
Hey, no problem Warbird19. It was fun BSing with you.
T
time only
461
Miami,FL
Jun 23, 2006
  • Jun 23, 2006
5 speed ~ 3.73 ~ " C " Springs Those are not the best setup for drag racing,but we have to work will what we get. How about removed/disconnect the front sway bar ? You could tried some taller tires to soften that launch. If you could borrow a set of 275 DR that will give you some more options .
V
Vortech88GT
Seattle
Jun 23, 2006
  • Jun 23, 2006
They came out with the 27" 255/15s the week after I got the 235s. Those would have been perfect. Oh well, I have these ones now so I guess I will stick with them... I haven't tried disconnecting the sway bar yet. Does that make a big difference? My plan has been to see how fast I can get the car with the super conservative vortech tune in full street trim. Once I get to a point where I don't think I can get much faster I plan on putting in injectors & PMS and removing a bunch of weight, maybe getting some skinnies, etc. to see what it can really do... Then it's time for the pullies
Stangler
A.K.A. Mr. Hankey
1,357
Jun 23, 2006
  • Jun 23, 2006
Good job!! I've had good luck with the 235's, but that is our class tire. you got way more power than mine though, mine is all 60ft!!
Nate
p.s. try 13-14psi in the tires for best results.
WaterPog
2,201
Portland, OR
Jun 23, 2006
#10
  • Jun 23, 2006
  • #10
The sway bar weighs about 20lbs, but if you want to leave it in just disconnecting one end will let the front end come up a lot better and get the weight over the rear wheels. Possibly some adjustable struts (strange would be my brand of choice), again to get the front end up and the weight back over the tires.
I don't think you want a taller tire, or less gear, with limited power like you've got you will want basically as much gear as you can get. You should be able to get into the 1.6 or 1.7 60' range with those tires once you get the car working correctly.
V
Vortech88GT
Seattle
Jun 23, 2006
#11
  • Jun 23, 2006
  • #11
Stangler - How are you launching on these tires? You must have cut some serious 60' times to get into the 12s at 101mph
Also, I do have adjustable struts (Koni reds) that I loosen up at the track to try and get a little more weight transfer.
WaterPog
2,201
Portland, OR
Jun 23, 2006
#12
  • Jun 23, 2006
  • #12
I know he was in the 1.6's but not sure exactly where. His suspension is all stock too, just worn out stock shocks and a C-4 with a 3000rpm stall and 3.73 gears. Stock motor from intake to oil pan, shortie headers, gutted stock H-pipe and 2.5" bullet mufflers with dumps.
It was really light at the time but the suspension just flat out worked for some reason.
The Koni's I thought were more of a street/road race style strut, compared to the Strange units that are geared toward drag racing.
Stangler
A.K.A. Mr. Hankey
1,357
Jun 23, 2006
#13
  • Jun 23, 2006
  • #13
yep! 2900-2950w/me in it.
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • Community Forums
