well I just took a 20 min test drive after installing 410s,and the early results are promising.I thought I noticed a faint whine on decel from around 40 mph on down to say 25 mph,but im not sure if that is tire/road noise or not, it may have been there with the old rear gears and I just never took notice to it. when I pulled into the driveway I reached under and felt the diff cover,expecting it to be red hot,and to be honest it really wasnt very hot.
one thing however is the fact that I did not add additional shims to preload the carrier bearings after I dialed in my backlash,hopefully the backlash doesnt open up much, it was around .009.
I dont know if I would have wanted to tear it all apart again,if there would have been some noticeable whine.I was thinking I would bite the bullet and take it in somewhere.to me that is a really rough job,extremely time consuming with having to do mock ups and such,especially when you are in a 1 car garage,and IMHO even interpreting gear pattern is tough unless you are gonna reinstall the axles,calipers,rotors,so you can put a load on by applying the emer brakes,I was using a rag wrapped around a breaker bar wedged between the ring gear.
BTW there is a redesigned crush sleeve,which supposedly only takes about half of the torque to get into the proper pinion bearing preload spec.
