bentley429isBAC
Don't waste any actual money on stock shortblock. Just go aftermarket and be done with it. I went through what you are doing a bunch with a turbo setup. Finally went aftermarket never looked back. Good luck
This is exactly my thinking. It the stock block craps the bricks next order is an aftermarket block. Then I can turn up the wick a bit.Don't waste any actual money on stock shortblock. Just go aftermarket and be done with it. I went through what you are doing a bunch with a turbo setup. Finally went aftermarket never looked back. Good luck
Which block are you using?Don't waste any actual money on stock shortblock. Just go aftermarket and be done with it. I went through what you are doing a bunch with a turbo setup. Finally went aftermarket never looked back. Good luck
That all depends.... what power level are we talking here? Race,street.....?Don't waste any actual money on stock shortblock. Just go aftermarket and be done with it. I went through what you are doing a bunch with a turbo setup. Finally went aftermarket never looked back. Good luck
Personally I wouldn't spend anymore money on a stock shortblock than I had to. While its apart you could grab a new balancer(I installed an sfi Pioneer unit from summit). I wouldn't bother messing around much with the rotating assembly other than the rings,bearings, etc etc.
Also a good set of studs or bolts won't allow head lift on a low to moderate boosted motor. The deck being uneven would allow HG failure. If going to cometics you'll need to deck the block anyway. Hopefully this will cure your issue. Just make sure your tune is safe. You're removing the HG as the "fuse" in the equation.
I'll see if I can find the info when I get off work. I paid around 150$ if memory serves.Which SFI Pioneer balancer did you get? I'm trying to figure out which one I should get instead of throwing an old stocker on there when I do my engine swap.
Power bond makes an awesome SFI balancer as well . I have the zero balance version . I had the 50 oz on the stock blockWhich SFI Pioneer balancer did you get? I'm trying to figure out which one I should get instead of throwing an old stocker on there when I do my engine swap.
3rd gear is usually the one that goes south when they're beat on. When they get some miles on them, the synchros will wear, giving you that "grind" between shifts we all love. What they can reliably handle usually depends on driving style. I've seen guys break T5 in stock cars, and other guys keep them together for years in 400 hp cars.What's the weak link in a stock T5 trans? How much power can the stock T5 reliably handle provided it's not abused like poor shifting technique and the like?
