Soldering O2 Wriring
  • Thread starter Thread starter rustyruststang5
  • Start date Start date Jun 23, 2012
R
rustyruststang5
151
Ne
Jun 23, 2012
  • Jun 23, 2012
can you solder O2 wiring? i burn one of my connectors on the exhause and i have a extra.
R
rustyruststang5
151
Ne
Jun 23, 2012
  • Jun 23, 2012
looks like from this site i should crimp the wiring
http://www.ericthecarguy.com/forum/topics.aspx?ID=3355
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jun 23, 2012
  • Jun 23, 2012
If its going to be permanent YES i would solder the joint. I did it in my car with no issues whatsoever. Get some heat shrink, slide it over the wire before you begin. Make the joint using solder, slide the heat shrink over the connection and shrink it down.. Butsplices have a tendency to come apart.
R
rustyruststang5
151
Ne
Jun 23, 2012
  • Jun 23, 2012
ya but did you read the link i posted?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jun 23, 2012
  • Jun 23, 2012
Yup. it was about a gauge installation, i didnt see anything about wiring.. Plus im an electrician, for low valtage dc circuits you need a high continuity low resistance connection for proper signal transfer... for a low signal current such as o2 readings to the pcm which register as low as .1 volts, i would never trust a but splice of any kind for continuity......
Voltage has the potential to bridge gaps it is called an "arc" anything involving 12 volts dc is soldered in my vehicle because of the low potential of the electromagnetic force involved in the circuit.
Just two cents from "sparky".
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 24, 2012
  • Jun 24, 2012
See http://oldfuelinjection.com/?p=7 for how to solder like a pro tips.
krazedstang
670
278
104
Streamwood
Jun 25, 2012
  • Jun 25, 2012
after reading this i'm gonna go check on my solders on my MAF conversion.....
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
