Solenoid?
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Apr 8, 2007
87Mustang351
220
Canada, Nova scotia, Cape Breton
Apr 8, 2007
  • Apr 8, 2007
hey guys jsut got the motor and tranny back in, pushed the clutch in, went to roll the car over n nothing, mydad has a book and there certain spots on the silanoid the certain wires should go?
so im goin to try that tomorow
but when we cross the silanode out, the car starts untll u take the screwdriver off of it, could this just be the wires or is my silanoide burnt out?
thanks
Todd
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
  • Apr 8, 2007
maybe you have the wires backwards.
87Mustang351
220
Apr 8, 2007
  • Apr 8, 2007
yea i think it maybe that my dads got the book that says the correct places for them so i will give that a shot tomrwoow and hope for the best, ps check ur pms i sent u one.
thanks
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
  • Apr 8, 2007
PM replied to.
K
krallman
96
Hurricane, WV
Apr 8, 2007
  • Apr 8, 2007
if the solenoid is shot its only like 10 bucks from the local parts store.
HISSIN50
34
129
Apr 9, 2007
  • Apr 9, 2007
You can test the wires at the solenoid (it's been covered and then some in the past). You also might want to ensure the clutch safety switch wasn't disturbed during the swap.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 9, 2007
  • Apr 9, 2007
87Mustang351
220
Apr 9, 2007
  • Apr 9, 2007
well, we got the car running today, crossed it over on the silanoide and took the screw driver off n the car kept running, so that means ym silanoide is toast, ill pick a new one up this week, and that clutch safety switch where is it located under the dash?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Apr 9, 2007
  • Apr 9, 2007
solenoid
HISSIN50
34
129
Apr 9, 2007
#10
  • Apr 9, 2007
  • #10
The solenoid is known to be toast only if before you did what you did, you tried jumping the small gauge wire on top of the solenoid to the battery lug and it would not turn over.
Otherwise, if your starter interlock circuit wiring is bad, a new solenoid won't help.
The clutch safety switch is located on the back of the clutch pedal arm.
To provide a systematic means of troubleshooting this (in the name of saving money on parts and time), perhaps we can persuade Jrichker to post his no crank list.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 9, 2007
#11
  • Apr 9, 2007
  • #11
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order. The clamp on with 2 bolts battery terminal ends are a know problem causer.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help for help troubleshooting voltage drops across grounds.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
87Mustang351
220
Apr 9, 2007
#12
  • Apr 9, 2007
  • #12
ok man this is what went down, my dad pulled the little red wire, crossed it over with a screwdrive and the car stayed running, so he told me the silanoids gone?
hes been workin on them all his life so im gonan give that a try on friday when i go home and hope for the ebsat if not im going to go through the list you gave me..
thanks a million!!
stang ruless
smr
167
Nor*Cal (Vacaville)
Apr 9, 2007
#13
  • Apr 9, 2007
  • #13
whats a silanoid?
4G-KDMP
935
CA
Apr 10, 2007
#14
  • Apr 10, 2007
  • #14
smr said:
whats a silanoid?
solenoid= starter relay in this case.
smr
167
Nor*Cal (Vacaville)
Apr 10, 2007
#15
  • Apr 10, 2007
  • #15
awwww...k seeign two things referenced above a silanoid and a solenoid..thanks for clearing that up for me....I kno wwhat a solenoid is thought a silanoid was something new...
87Mustang351
220
Apr 10, 2007
#16
  • Apr 10, 2007
  • #16
i just dont bother to try spell it right, people get my point
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 10, 2007
#17
  • Apr 10, 2007
  • #17
Punctuation and good spelling make the post more readable. Some of the problems can be made easier to solve if it isn't necessary to translate from redneck to proper English. I have given up several times because the problem description was just too hard to read and understand.
Another reason good spelling and grammar are important is so that people don't get the impression that you are a bonehead.
If people think you are ignorant, they tend to ignore your posts. This is probably because they think that you won’t understand anything that is complex. They don’t want to waste their time trying to explain what they posted.
You probably are a smart guy, so let us see it with posts that show the intelligence that you have.
smr
167
Nor*Cal (Vacaville)
Apr 10, 2007
#18
  • Apr 10, 2007
  • #18
valid points in so many ways....
87Mustang351
220
Apr 10, 2007
#19
  • Apr 10, 2007
  • #19
i am smart and know what to do with motors and what not, but im just not the gretest speller thats all
but like i said i appreacte your help, and everyone elses, i just cant be bother to try spell things right lol, and i try explain as best i can
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
C
Engine No Crank Issue (But Starts When Jumping Big Terminals on the Starter Solenoid)
  • Cabernet88GT
  • Jun 6, 2021
7K
Fox 5.0 Mustang Tech Jun 6, 2021
Cabernet88GT
C
