solid motor mounts..but solid tranny mount?
  • Thread starter Thread starter xoxbxfx
  • Start date Start date Jun 26, 2006
xoxbxfx
3,959
Southlake, TX
Jun 26, 2006
  • Jun 26, 2006
Should I go solid or rubber mount for a transmission when using solid motor mounts? I didnt really want solid mounts up front but there arent a lot of options with a MII
BornInAFord
199
Bend, OR 97701
Jun 27, 2006
  • Jun 27, 2006
I think you'll feel a LOT more vibrations through a solid transmission mount than you'll feel with your solid engine mounts--you sit right beside the transmission and basically on top of the transmission cross-member, whereas the engine is a little more isolated up front. I've got a stock rubber mount on my T5 and poly motor mounts. I can feel a little vibration (not as much as solids), but not nearly as much as when the shifter base was bumping up against the tunnel opening (equivalent of a solid mount).
Daniel
R
Ronstang
1,294
Houston Texas
Jun 27, 2006
  • Jun 27, 2006
You should not have all points on solid mounts. If you have solid motor mounts then you should keep a rubber/poly isolated one on the tranny. You can actually break the transmission case from what I have heard although I cannot verify that. You would also have a lot more vibration with a solid transmission mount also.
LUCAFU1
496
Tucson
Jun 27, 2006
  • Jun 27, 2006
i got rubber mounts with my heidts kit. i want some solids. if you wanna trade let me know. i was planning on drilling and bolting the mounts together. i havent seen any solids for sale anywhere.
LUCAFU1
496
Tucson
Jun 27, 2006
  • Jun 27, 2006
I have solid motor and tranny mounts in my cobra and no problems yet. also on my old fox i ran solid all around w/o problems. i would think rubber mounts and a solid tranny mount would give you problems when the engine torques.
R
Robdogg67
148
Seattle/Tacoma, WA
Jun 27, 2006
  • Jun 27, 2006
I would go with a poly from summit on a modified car. Good vibration dampening and has the interlock for increased safety over stock. Is there a good reason to go solid throughout?
xoxbxfx
3,959
Southlake, TX
Jun 27, 2006
  • Jun 27, 2006
Thanks but I have already fabbed up everything. The frame backets are welded and powdercoated, the engine side brack is all welded... Im just gonna stick with what I got.
Thanks guys.. I will be using the stock tranny mount for the 3650
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
D
Resolved Vortech hitting hood
  • Dchichizola
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
General karthief
