solid motor mounts
  • Thread starter Thread starter 873Stang
  • Start date Start date Apr 9, 2007
873Stang
221
riverside
Apr 9, 2007
  • Apr 9, 2007
just installed some maximum motorsport solid motor mounts and holy **** my car vibrates really bad once its pass 1,500rpm's is that normal??? i started thinking my harmonic balencer is bad but someone told me its the mounts. if it is then im going back to stock ruber ones. whats your opion thanks
M
muttstang
39
Aurora Ont. Canada
Apr 9, 2007
  • Apr 9, 2007
I have heard this is common I am about to put my solids in and i am hoping it won't be bad.
I had an 89 S10 with a 400 small bloak chebby in it with solids and I didn't mind it
4G-KDMP
935
CA
Apr 10, 2007
  • Apr 10, 2007
that's the problem w/ soild mounts, you, feel all the vibrations even if there is nothing wrong you'll feel it.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Apr 10, 2007
  • Apr 10, 2007
Ditch those on a street car!! Get the stock ones from a convertible, they are a different style then the hardtops, and they are still rubber. Or you can go with the poly mounts, from www.50resto.com
9
90bluegt
592
  • Apr 10, 2007
I got the solid mounts and only at idle does the car vibrate. While cruzing and such the car is fine, doesn't really vibrate any more than before.
302RollinHard
Columbus, OH
Apr 10, 2007
  • Apr 10, 2007
Mine doesn't vibrate while driving per se mine does "pulsate" while driving though from the massive amout of power under the hood. You will get used to it. Mine would rattle @ idle, now all the rattles seem to have taken care of themselves.
ghostang93
29
Pace, FL
Apr 10, 2007
  • Apr 10, 2007
If you go back with stock rubber type mounts, i believe the 93 GT's, are the same capured mount design as the 'verts. You could also look into poly mounts, maybe some of the members here have those
ronburgundy
179
BC coast
Apr 10, 2007
  • Apr 10, 2007
i have the energy suspension poly mounts, luv em.
LASTFOX
105
RI
Apr 10, 2007
  • Apr 10, 2007
ES is definitely the way to go...got 'em on the motor, trans. and x-member. Strong and rides like stock!
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
