Some diff questions
  • Thread starter Thread starter blue66tang
  • Start date Start date Jun 20, 2004
blue66tang
1,092
Medford, OR
Jun 20, 2004
  • Jun 20, 2004
As probobly most of you know i blew my 8" not to long ago, and nowi am going to do a 9" build up. I would like to put a detroit locker in it. Who makes good detroit lockers. I was looking at ford racing but they have no warranty. Any sugestions out there. I amtrying to save as much money as i can. What about ebay. Thankks
6Stang7
1,470
Livermore, CA
Jun 21, 2004
  • Jun 21, 2004
Honestly, getting a locker is a bad idea. I got a Detriot EZ-locker and had it professionally installed and the pos didn't work. It has been over 3 months and I still have yet to get a refund. I know you're trying to save money here (that was the same reason why I got a locker) but in the end you'll just wish that you had saved the extra and gotten a LS unit. I drove a car with a locker in it about 2 weeks ago and I have to say, it was a PITB! Lockers work differenltly then a LSD, so you have to make slight throttle adjustments, otherwise the car will pull hard one direction. You have to be carefull when braking too, cause if you brake too hard, your car will pull one way. You also have to really careful going though turns, cause if you give it too much throttle (and too much is almost nothing) then you'll end up with your a$$ end in the next lane. My advice is just save up the extra $200 (that is all) and get a really good LSD. Trust me, all the cheap lockers suck!!!
302 coupe
1,952
Macon, Ga.
Jun 21, 2004
  • Jun 21, 2004
Well, Detroit makes a good Detroit Locker. Just like Eaton makes a good Eaton Posi. Maybe I don't understand your question.....
Ford Racing won't put a warranty on anything, very few hi performance parts come with a warranty. If its installed, its yours, if it breaks, its your fault. Detroit has set the standard for 40 years, if its reputation doesn't sell it nothing will. Lockers are for the strip, limited slips/posi's are for the twisties.
blue66tang
1,092
Medford, OR
Jun 21, 2004
  • Jun 21, 2004
Actualy the limited slips are cheaper. I think detroit lockers are different then the ez lockers. Detroit lockers came in teh shelby cars witch were for street use. Basicly i want something that i dont have to rebuild every year or so and wont slip at the drag strip with slicks. Im not worried about driving a locker on teh street i drove with a mini spool for about a year so i know i can handle that, and i drive it about 5 times during the fall/winter/sping.
What is everybody else running in their 9"s.
F
fastcoupe68
368
nj
Jun 21, 2004
  • Jun 21, 2004
Go with a Detroit Locker! You cant beat them. Moser engineering sells them and so does Ford Racing, Summit and Jegs
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jun 22, 2004
  • Jun 22, 2004
What he said!
HistoricMustang
2,359
Confederate States of America
Jun 22, 2004
  • Jun 22, 2004
The Detroit Locker will do you just fine. Especially at the strip.
I have used one road racing for years with no problems.
Check with Currie Enterprises.
HistoricMustang
www.historicmustang.com
G
GaPonyFarm
663
Columbus, GA
Jun 22, 2004
  • Jun 22, 2004
Once you get used to the quirks of the Detroit Lockers, you'll be fine. There is not a better differential made...none.
Having said that... The is nothing wrong with Ford's 9" Trac-Loc. Its pretty tough and rebuildable...and perhaps most important for a mostly street driven car, a dime a dozen cheap. Check local junk yards and swap meets.
blue66tang
1,092
Medford, OR
Jun 26, 2004
  • Jun 26, 2004
if i went with the trac loc what one should i get. I know there is at least 2 different kinds. How do you tell them appart. If i do get one, i probobly will end up getting one off of ebay, there hard to find around here.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
