  • 1994 - 1995 Specific Tech
Some questions
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Sep 26, 2005
9
95mustang_gt
364
Wisconsin
Sep 26, 2005
  • Sep 26, 2005
I just have a some questions.when i was installing the filter for my cai,i saw this bar that had 25lbs on it.What is it and can i take it off?
Another question is that im getting to new tailpipes,so im taking my exhaust off,to save a little money im going to take the exhaust off myself and take it to get the stuff welded together.Is it diffcult to take the catback off and what tools do i need?
Im Also wondering,if i need to drive the car,can i drive without the catback?
thanks
Jesse
T
Threeotwo94
38
Hamilton, New Jersey
Sep 26, 2005
  • Sep 26, 2005
Im pretty sure that the bar you saw is just added weight from the fac. I think they call it a dogbone not too sure.
As far as the Cat Back question it shouldnt be too hard as long as everything isnt rusted together. Ive had my exhaust off a lot but the last time I took it off I broke a bolt. All depends.
Youll just wake up the neighbors without you cat back on.
CManT1914
3,172
Killeen, Texas
Sep 26, 2005
  • Sep 26, 2005
That is the cowl weight, it's supposed to help reduce cowl vibration on verts. Take it off, you don't need it. Pretty much every vert guy takes their's off, I have, and haven't had any problems. The dogbone is the 8lb weight back where the differential is.
thanks
Jesse
It's an aftermarket one? Usually they just bolt together. Either way, taking off a catback is real simple. It will be real loud driving without it, but you should be fine if you're just going to and from the exhaust shop.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 26, 2005
  • Sep 26, 2005
Yeah, you can take that weight out. No problems here either.
Second, you can remove the cat back with a good socket set, some penetrating oil, and a hacksaw (or grinder). You will have to cut the tailpipe somewhere around the area of the axle.
3rd, you can run the car w/o a cat back. No problem.
Scott
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
