  • SN95 4.6L Mustang Tech
Some Toys (need some input) *PICS*
  • Thread starter Thread starter BlackenedSVT
  • Start date Start date Mar 4, 2006
First Prev 2 of 2
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 9, 2006
#21
  • Mar 9, 2006
  • #21
you might wanna get one of those feeler gauges so you dont go too thin w/the porting
BlackenedSVT
1,841
New Jersey
Mar 9, 2006
#22
  • Mar 9, 2006
  • #22
i have feeler gauges....too thin where though?
M
mijo_latino
179
Canton, Michigan
Mar 9, 2006
#23
  • Mar 9, 2006
  • #23
This was my first attempt at the inside and second on the outside. No need for the plate you have there, as I think if you just smooth out the top it makes it look cleaner. A tip would be to have the right steps of sanding grit as jumping too far apart will get frustrating.
BlackenedSVT
1,841
New Jersey
Mar 9, 2006
#24
  • Mar 9, 2006
  • #24
wow, how long did that take?! Looks damn nice though.
What kind of dremel did you use exactly, and with what bits/tips?
QDRHRSE
1,590
Palmdale, CA
Mar 9, 2006
#25
  • Mar 9, 2006
  • #25
You could always sell that pump assembly to me. It's the same as a Lightning and I wouldn't mind freshening up my pumps.
M
mijo_latino
179
Canton, Michigan
Mar 10, 2006
#26
  • Mar 10, 2006
  • #26
Thanks UDT, I used a multispeed dremel. The higher speed was to shave off thick parts, which was by a carving bit. The dremel usually spent its time on the lowest setting due to sanding and just not wanting to fry the dremel.
What i used was the sanding drums the kit came with at first. It only came with a few so i went and got some regular sand paper sheets and made strips to put around the drums with doublesided foam tape. This worked great as you can have unlimited supply of various grit drums.
I would say start with 100-200, then 400, and finally 800. Try to see what works for you. I only had 120-220 then to 600(too much of a jump) and 800-1000. Finally a had some Mother's metal polish and it worked great. Only its hard to get the shine perfect, it has a small haze if you look directly at the surface.
You may want to get a dust mask and some simple gloves, the shavings get everywhere... I think thats it, good luck! err time? i dunno a couple hours here and there, just something i would pick up during the week.
First Prev 2 of 2
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
